jmaxwell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Guys,
What is your step-by-step procedure when doing a general IR home inspection. Also any tips, tricks, best way to manipulate delta-t, camera settings, best times, limitations or any thing else you can think of would be appreciated. Thanks |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi James,I go with the flow, just like I'm doing my H.I. What IR classes have you taken? Remember, it's just another tool in the bag, not an end all be all.
Practice, practice, practice. Mic |
Chris Mayes, President / CEO AC Tool Supply, Inc. Energy Auditor Talk "Fluke Infrared Cameras Save Lives In Haiti" Read the full story |
Do yourself a huge favor....Please don't attempt to learn IR camera functions and settings and proper conditions through this MB. Sign up for Level One training and you will learn everything you need to know about all IR cameras and you will then shine (as a professional should) when you perform an IR scan. |
Kinda sad, seeing them get all squirmy on the stand. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Recognizing the need for standardized procedures, Infraspection Institute began publishing guidelines for thermography in 1988. Since their initial publication, Infraspection Institute guidelines have been adopted by hundreds of companies worldwide and incorporated into documents published by recognized standards organizations such as the American Society for Testing and Materials (ASTM). Beginning in 2007, Infraspection Institute guidelines were updated and renamed as standards to reflect their industry-wide acceptance and the best practices they embody. Each Infraspection standard provides simple and straightforward procedures along with the requirements for properly documenting test results. Infraspection application standards provide a blueprint for both specifying and performing infrared inspections and are designed to be incorporated into contract documents. These documents are a ‘must-have’ for anyone who specifies, performs, or oversees infrared inspections. The Infraspection Institute Standard for Infrared Inspection of Building Envelopes outlines practices and procedures for specifying and safely performing infrared inspections of building envelopes to detect excess energy loss, latent moisture and structural details. This 11 page document defines the roles of all persons involved in the inspection including the owner and thermographer. It also specifies report content for properly documenting infrared inspections along with requirements for verifying infrared data. The Standard is available in PDF format for $25 USD from the Infraspection Online Store. If you are new to thermography, I too, would recommend that you take some formal training before you get started. At a minimum, I would suggest our 16 hour application course, Infrared Inspections for Home & Building Inspectors. If you are looking to truly unlock the earning potential of your imager, I would recommend our Level I Certified Infrared Thermographer course. Both courses qualify for NACHI continuing education hours and are available as open enrollment courses or via Infraspection Institute's Distance Learning program. Hope this helps. Jim Seffrin, Director Infraspection Institute 425 Ellis Street Burlington, NJ 08016 609-239-4788 SuccessIRies.com IRINFO.ORG IRINFOConference.com |
InterNACHI's Offical INFRARED CERTIFIED Training (live webinar - 16 hours)
I've looked at every IR curriculum. I like Infraspection's Course for Home and Building Inspectors and I love John McKenna's Infrared Certified Training for the exact same reason: Both are designed especially for home inspectors. If nothing else, the direct tie to our profession will keep the training interesting, if that makes any sense.
That same reasoning prevents me from being a fan of Level I or II training, which I find to be more camera-centric than we really need. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 2/21/10 at 2:29 AM.. |
Check out these from Infraspection, as well: http://www.successiries.com/
The first two are free to watch. JJ |
Also, the course that I developed and teach. Also 16 hours and complys with ANDT standards. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! Last edited by wdecker; 2/21/10 at 3:36 PM.. |
Excellent!
| Garage door inspection procedure | bgromicko | General Inspection Discussion | 5 | 8/7/09 12:47 PM |
| What is your HVAC procedure? | sstowe | Inspecting HVAC Systems | 66 | 5/28/09 12:48 PM |
| policy and procedure manuals for inspectors | jcordell | Miscellaneous Discussion for Inspectors | 3 | 2/9/06 9:10 AM |
