Incorporating infrared inspections with traditional home inspections can be a new source of revenue for the traditional home inspector. This paper will discuss which areas of the marketplace are best suited for infrared home inspection and how to create recurring income from this type of inspection. It will also cover what to look for and be aware of during an infrared survey as well as best practices to reduce your liability when producing your infrared home inspection report. Introduction Buying or selling a home is a major life event for most people. It seems reasonable that buyers would want an objective opinion from someone who has experience in home inspections. Is experience enough? What is enough experience? What is required to be a “State Certified Home Inspector”? Those requirements change from state to state. In Florida there is no certification necessary, a business license is all you need. There are organizations such as The American Society of Home Inspectors (ASHI) where one can seek some credibility. Discussion Most people who are buying a home have a few reasons to purchase a home inspection. First “it is a good idea”. They also need a budgetary estimate on the damage that is reported. The budgetary estimate is necessary to buyers who plan to finance conventionally. The Limited Repair Clause that was written in most listing agreements allows the seller to control the cost of repairs if any are found after an offer has been made and deposit has been given on their property. It is usually two or three percent of the property value. The buyer sees this clause as “find the damage now or forever hold our peace”. The information received from the home inspector’s report is often necessary to exercise the limited repair clause. In a perfect world the report would read “this is a great house, there is nothing to report”. In most cases, repair clause monies are deducted from the total price of the property at closing. Infrared Home Inspections are becoming a must to high-end home buyers and investors. A weak stock market and low interest rates have created many newcomers to the real-estate marketplace. We have found that the high-end client’s needs are greater than the average home buyer due to larger properties and higher demand for additional information. Insurance companies have a need for inspectors to help adjust their claims. Public claims adjustors have a need for an outside opinion. They want the peace of mind of knowing that whatever the final buying decision is, valuable information was shared that justified one’s action to buy or not to buy. Home inspections should supply all these needs, and infrared home inspections assure the buyer that if there is damage to find, this technology and your expertise will find it. Here are some basic areas to inspect during a standard home inspection using nothing more than a flashlight, ladder and perhaps a moisture meter. General:
Roofing:
Exterior:
Subfloor Area / Basement:
Interior:
Kitchen & Bathrooms:
Electrical:
Garage:
Heating / Cooling:
Fireplace:
Example of damage and Limited Repair Clause: The following photos are of a home that was sold for $750,000. There was a 3% damage repair clause that equaled $22,500. We will look at how infrared adds to this home inspection and helps to meet the end user’s expectations as well as their needs. Without infrared proof, the repair estimate would have been significantly less money. These are some photos typical to a traditional home inspection part of the report. ![]() A termite inspection and roof report was also required by this client. Most home inspectors outsource this task to a licensed pest company and licensed roofing company. With infrared home inspections, we can combine the termite report, roof report, and enhanced home inspection report. This repot is supplemented with photos, as seen above. This service is valued at about $250 to $300 for an average sized home.You can add to, refine, and customize your checklist and report, but remember your client’s needs: beware of over reporting or reporting on items that can be easily checked by the end user. Stand alone Infrared Home Inspections without any other issues to report on except moisture, energy conservation, and pests, can be of great value to the end user. The way we perform this type of inspection is room by room, documenting ceilings, walls, and floors. The scope of the inspection consists of: Moisture Survey, Energy Survey, Leak Detection, Fungi and Wood Destroying Organisms. A visual inspection of the attic, crawlspace, exterior of the home and foundation are also performed. This part of the inspection is so that if we discover major repair issues or safety concerns we can report them; however, I do not render a structural opinion on a home. If we couple the traditional Home Inspection with the Infrared Home Inspection, a new product emerges that meets the needs of the end user. The average price changes from $250 to $300 for a visual home inspection to $750 to $2,500, thus a creating a new market for the high-end home buyer. This is a market where the prospective clients are desperately awaiting these services. In this home, there was a false chimney enclosing the exhaust system for a wood burning stove. As you can see, there is a thermal difference. ![]() Inspecting further we found that the wood siding read 20% plus. The end result was that a “walk on roof inspection” was necessary and showed the top exhaust stack was not closed properly and thus water was leaking in. ![]() The basement wall has a moisture problem, which brought damage repair dollars to the buyer. ![]() Moisture meter readings were over 20% in some of the wood siding where the arrows are pointing. The buyer used this information to finalize his offer to buy this home. This client spent $1,500 on an IR Home Inspection and Termite Inspection and received tens of thousands from the seller for repairs. Combining the practices of the traditional home inspection and an infrared home inspection produces a better service to the end user. Let’s look at some stand-alone infrared home inspection images taken after hurricane Wilma for insurance purposes. ![]() The wall that had shown this anomaly is common to the A/C handler closet of which is leaking above the ceiling line. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Liability is a factor that must be managed. Here are some ways to reduce the risks. The obvious is watching what we say and write. Maintain quality in all your home inspections. Establish standards and stick to them. Use accurate language when speaking or writing about your inspections. An example is the word “mold”. This word can get your company into a high risk situation. A better way to describe this natural process is “Surface Fungi”. ![]() ![]() The best way to have recurring income in the home inspection industry is any way that you can get it. It is that important of a factor as it relates to your business growth and net worth. Some of the ways that I have provided recurring income in my IR home inspection division have been developing the right contacts; I woo brokers as opposed to realtors; I build relationships with developers as opposed to contractors. I stay in touch with my clients; I bundle IR home inspection services together with other targets such as roof and pest inspections that need annual service. Then, I perform an IR moisture inspection and preset the yearly renewal fee in the initial inspection agreement. You can pick up 20% or 25% of the initial inspection cost each year. The commercial marketplace is another good area to find recurring income due to the fact that commercial building owners are into preventive maintenance programs, and this could mean scheduling inspections a year or two in advance at a predetermined fee. For more ways, use your imagination, be creative, keep the end user’s best interests in mind and make money. Attached is a home inspection checklist for you to use while doing a standard home inspection. I sincerely wish you well in this area of thermography! John McKenna, CMI (TREC #4565)
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 12/18/07 at 5:08 PM.. |
Very important info Thanks John
....Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Wow! That was great!
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Very informative
Mic |
| How crazy has the Toronto Real Estate Market become? | cmettel | Canadian Inspectors | 4 | 6/11/07 2:29 PM |
| As Market Cools, Home Buyers Seek a Way Out | jburkeson1 | Miscellaneous Discussion for Inspectors | 4 | 5/10/07 1:23 PM |
| SoCal Housing Market Holds its Ground | whandley | Miscellaneous Discussion for Inspectors | 0 | 5/3/07 12:12 PM |
| Hot market hurting home inspections | rwand1 | Canadian Inspectors | 9 | 5/25/06 7:35 AM |
