Log walls?
If there are surface temperature changes associated with it.
Density will effect thermal capacity and it will show up. It is not likely that you will know what your looking at through the camera though. Wood knots show up for the same reason.
I'm sure there may be better tools to evaluate this though! |
Ken,
The IR camera measures the surface temperature. The log may have moisture reaching the surface that is at the stage of evaporation and would be cooler than the area around it, and this would cause the camera to see this difference in temperature (delta-T). If the moisture was at the same temperature as the surrounding surface, then the camera would not see it. Buy turning on the heat or AC you might be able to change the interior temperature from the exterior and thus cause the moisture to show up on the cameras image (maybe). If the decay is dry, it would be the same temperature as the rest of the log and the camera would not see it. If the density of the log causes the log to absorb temperature at a different rate, then some areas would look differently on the cameras image. Just some food for thought. Trying to see the logs from the outside in the sunlight would be difficult because the solar energy would saturate the logs with heat. The wind and clouds going by could have an some affect as well. If there is moisture deep within the log, it would be difficult to see any difference coming to the surface. There are a lot of factors to consider. You might find more information about the logs by pounding on them with a mallet and listening to the sound that they make and then look for defects in the areas that do not sound right. See Kenton Sheperds video on log homes. http://www.nachi.tv/episode5 John McKenna, CMI (TREC #4565)
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 12/31/07 at 10:37 PM.. |
| Can someone explain why wood in contact with concrete causes rot? | gromicko | Miscellaneous Discussion for Inspectors | 46 | 1/16/11 11:15 PM |
| Roys Radio show | rcooke | Canadian Inspectors | 12 | 11/13/07 6:24 AM |
| NACHI has the corner booth at the Toronto Real Estate Trade Show on April 24-25, 2007 | gromicko | Canadian Inspectors | 7 | 7/1/07 9:30 PM |
| NACHI Booth at Fairfield Realtors Trade Show Pictures | mroe | Miscellaneous Discussion for Inspectors | 3 | 5/24/06 11:16 AM |
