mroach is a non-member guest and is in no way affiliated with InterNACHI or its members.
How are you guys going about keeping up with the pictures on cameras that do not have voice notes are PIP? I have the Bcam SD
I did a large home 4,500sf and found lots of problems. When I sat down to write the report I had a heck of a time remembering what picture was what. Thanks' Mark |
| Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America) |
Put the date and time stamp on your IR pictures and your digital pictures.
Problem solved. John McKenna, CMI (TREC #4565)
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't use IR, but for regular pics I take a pic of the whole room (or area) as a first shot. Any pic following that will be in that room or area, until the next "entrance" shot.
I imagine you could do the same with IR. |
All good points.
Here is what I did when I had my BCAM. I would clear the memory cards from both cameras IR and Visual (start from 1). I would shoot both IR and Visual one after the other. Having my visor/camera mount also helped. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com Last edited by mkyriacou; 10/17/09 at 1:01 AM.. |
I have a picture log that I use, basically it has a JPEG # with a description then next to it a IR # with a description. It does get confusing especially if you do two in one day.
Peter, memory cards are so cheap ($20) that you might want to just pick up a second memory card for the 2nd job. Or , many cameras can create folders for separate jobs which you can use as well.
2008 InterNACHI Member and Innovator of the Year HOME INSPECTOR PRO HOME INSPECTION SOFTWARE NOW ONLY $499 ($15O OFF!!) Easy to use, customizable Home Inspector Software that runs on Windows, Mac, Android & Linux InterNACHI members receive 3 months of FREE home inspector website hosting List yourself in our Home Inspector Directory Free Watch our NACHI.TV Software & Search Engine Optimization videos! Help@HomeInspectorPro.com |
Pick up a cheap digital voice recorder and when you save an image to your camera, dictate the image number into the recorder and make any comments you might have. You can pick up voice recorders for around $50.00. It will save you a lot of time writing stuff down and trying to ready your own writing after the inspection.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Ditto what John recommends, and develope a routine for each room. For example, always go in a clockwise motion, then scan each wall top to bottom, from left to right, when you find an exception, then zero in on it, snap a couple more photos then move on to the next room.
I do quite a few IR inspections and have the routine down so I'll stay with what works for me. Having two cards doesn't help because it's trying to remember what each IR picture is or what it was. After taking a couple of hundred pictures, digital and IR in one day they can get confusing. I like the voice recorder idea but many times you may have the seller or Realtor up your you know what and would like to keep your thoughts to your self.
All good ideas though |
Memory cards are great but the most important thing you must do is to establish a starting point in every home. I always start my IR inspections at the front door and I work my way around the first floor until I reach my starting point (front door). I then get a picture of the stairs and start the second level the same direction.
With this method, I've never had an issue with identifying an image on my report software. |
I use my visible light camera in conjunction with my IR camera. When I'm about to capture an IR image, I freeze the frame then take a visible light image of the IR camera display and use the voice annotation feature of my digital camera to identify room, area, anomaly being recorded, etc. Once I've done this I record the frozen IR image to the thermal cam memory and take a visible light image of the target. This allows me to match up my digital and IR images, regardless of how many images I capture with either.
It may sound complicated, but it's really very straightforward and beats taking notes on paper. I can also go back at any time in the future and know exactly what I was doing because all of my notes are stored with the images. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 5/23/09 at 9:38 AM.. |
I use this camera
It takes infrared and digital pictures simultaneously. http://www.flirthermography.com/came...camera_id=1111 Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
My imager does not have PIP so I use an additional digital camera. Clear cards on both, snap photo with imager then with digital. May use a notepad or voice recorder also depending on conditions found. After a few inspections you will find what works best for you and then move forward from there!!
[QUOTE]
'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
| Pictures Needed | kgoff | Miscellaneous Discussion for Inspectors | 1 | 4/16/07 7:53 PM |
