Old 7/23/08, 4:46 PM
Default leak on exterior wall
I'm having too much fun finding wild and crazy stuff
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 7/23/08, 5:02 PM
sfalvey sfalvey is offline
Default Re: leak on exterior wall
Kevin,
It looks like there is a stain on the outside of the siding on the right side where the small streak is. Does the leak also cross over horizontally and drip down further to the left on the inside (underside) of the siding?
Nice find.
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 7/23/08, 5:18 PM
Originally Posted by sfalvey
Kevin,
Nice find.
This was actually a no brainer. There was a leak on the condensate drain line for the second zone in the attic. The builder "failed" to terminate the end of the discharge pipe through the soffit. The pipe was cut too short, so when the pan filled up, all of the water leaking from the drip pan drained inside the wall cavity all the way into the basement.
The staines you see in the image above are from the exterior. There's two seperate streaks of water flowing down the side of the house.
I love this stuff
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
IAQ Testing From 2nd Story Bathtub Leak??? Ed Fako Ancillary Inspection Services & Additional Topics 10 2/21/09 11:02 AM
Leak in water line outside ... what is ... Bill Featherstone Plumbing Inspections 6 1/12/08 9:17 PM
Leak in copper, rerouting w/ plex rkeith Plumbing Inspections 1 4/24/07 9:22 PM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
