Old 12/19/07, 4:44 PM
Charley L. Bottger's Avatar
Default Lets get it on
Ok guys flat roof ice standing 10:00 AM clear no wind why is this temp reading 7 degrees on the ice E-setting 70
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/19/07, 5:30 PM
David P. Valley's Avatar
Default Re: Lets get it on
Reflection from the sun.
Old 12/19/07, 5:40 PM
ldapkus ldapkus is offline
Colder areas are shaded from the sun.
Old 12/19/07, 5:51 PM
David A. Andersen's Avatar
Reflection of the sky.
All reflective surfaces will read the surrounding temps (at some point on them depending on their shape) rather than their temp.
Example: Watch out for breaker panel terminal lugs, they look hot because of your body heat.
Old 12/19/07, 6:11 PM
Yup, and most will look hotter than others but you must actually go by the actual temperature of the area in question. If you see a thermal image of a breaker reading a temperature of 110 degrees, it may not be a problem verses seeing a breaker hot spot at 210 degrees.
Your e-setting for this application is too low.
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 12/19/07, 6:12 PM
New shiny conduit looks hot too. It fooled me the other day when I was showing a builder my cam.
Old 12/19/07, 6:19 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
[quote=dandersen]Reflection of the sky.
Dave
Exactly!! That's why roof (inspections)scans should be conducted in the evening.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 12/19/07, 6:28 PM
Attic door, colder in the attic than in the house.
Where is the hot spot coming from?
My reflection.
Old 12/19/07, 6:30 PM
Why is that?
The sky is the same temp, day or night (if it is clear and low humidity)?
Old 12/19/07, 7:06 PM
Why is that?
You tell me Dave. If you are conducting a roof moisture survey why would you do it in the daylight.
Would it not be better to do it after sunset? This will eliminate reflections,shadows and allow you to detect roof moisture. But you already know this stuff you are Level 3!!
Tel.# 416-722-6132
Old 12/19/07, 7:19 PM
William Warner's Avatar
William Warner William Warner is offline
The thermal window is open the widest in the early morning or late afternoon/early evening. It is typically at its most narrow margin at high noon. As water has a high thermal capacitance, the chance to observe moisture on a flat roof is at its greatest potential in the mornings and evenings especially with a less sensitive camera.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 12/19/07, 7:23 PM
You tell me Dave.
I am seriously asking you.
There are many good reasons to do roof scans at night. As you posted.
My question is why in this case would the ice show up differently at night?
Old 12/19/07, 7:33 PM
Thank you Mr. Warner.
I was taught a method of determining the maximum Delta T by monitoring the temperature of the roof and the temperature of water in a container. In the morning you'll receive the greatest temperature difference as the roof begins to warm more rapidly than the water. At some point around midday, it is likely that the water temperature will match that of the roof temperature. Later in the evening the roof will cool more rapidly than the water. At some time late at night, just like at high noon the temperature of the roof and the water will equalize.
Old 12/19/07, 7:35 PM
Guys this was not a test I was surprised my self when the low temp showed up I was not actually scanning the roof was the wrong time of day especially with the water frozen. And yes my instructor did say the night time after radiation cooling takes place never scan a roof in the heat of the day. you are looking for evaporation of the water beneath the roof covering; water holds the heat longer and will show up.
Yes I did have the wrong E setting I just happen to have the camera in my hand when I went on the roof as I had been called to check an interior wall which I will post later I just wanted to view the roof before I went inside. Just forgot to change the E-setting for the roof. The outside ambient was in the low 30's when I snapped that IR pic. But that still does not explain 7 degrees as nothing in the area was that cold. When I am just playing with the camera I will often change the E-setting just to see the variances in the temps.
As for the breaker temp being discussed my instructor stated the allen set screw hole will create a reflection or cause the actual temp to be off and has to be adjusted for. There is a specific name for this and I can not recall the name without going back to my books. I was not jacking with any one don't have a clue why the temp in the pic was so low. I am open for serious discussion.
NACHI Member
State License # 130
