Old 12/18/11, 4:30 PM
Dustin C. Phillips Dustin C. Phillips is offline
Default Like New FLUKE TiR THERMAL IMAGER
Purchased in August 2011 and used only a handful of times! Paid $5,000 and hoping to re-coup around $4,500 OBO. Email dustinphillips14@hotmail.com for more info or to make me an offer!
Optimized for building envelope, restoration and remediation, inspection and roofing applications.
The Fluke TiR Thermal Imaging cameras are the perfect imagers for building envelope, restoration and remediation, inspection and roofing applications.
IR-Fusion® Technology
See things both ways—infrared and visual (visible light) images fused together communicating critical information faster and easier—traditional infrared images are no longer enough. IR-Fusion, a patent-pending technology that simultaneously captures a digital photo in addition to the infrared image and fuses it together taking the mystery out of IR image analysis. IR-Fusion is standard on TiR models.
  • Includes IR-Fusion® Technology both in camera and software (combines visible image with IR image in full screen or picture-in-picture views) for easy identification and reporting of problems
  • Rugged and reliable: Engineered to withstand a 2 m (6.5 ft) drop
  • 9.1 cm (3.6 in) diagonal landscape color VGA (640 x 480) LCD
  • Temperature range and thermal sensitivity optimized for building diagnostics applications
  • Perfect for any application and budget
  • Excellent thermal sensitivity for seeing even small temperature differences (which could indicate problems)
  • Adjustable hand strap for left- or right-handed users
  • Everything needed to get started is included.
    Training DVD is now included free. See how easy it is to set up your thermal imager, create professional reports with SmartView software and learn thermography theory with step-by-step video instructions.
  • Manufactured in the U.S.A.
Detailed specifications
Temperature performance Calibrated temperature range -20 °C to 150 °C (-4 °F to 302 °F) Accuracy ±2 °C or 2 % (whichever is greater) Measurement Modes Smooth auto-scaling and manual scaling
Imaging performance Field of view (FOV) 23º horizontal x 17º vertical Spatial Resolution (IFOV) 2.5 mrad Min. Focus Distance Thermal lens: 15 cm (6 in)
Visible (visual) light lens: 46 cm (18 in) Focus Manual Image Frequency 9Hz refresh rate Detector type 160 X 120 focal plane array, uncooled microbolometer Infrared lens type 20 mm F = 0.8 lens Thermal Sensitivity (NETD) ≤ 0.09 °C at 30 °C target temp. (90 mK) Infrared spectral band 7.5 μm to 14 μm Visual camera 640 x 480 resolution
Image presentation Palettes Ironbow, blue-red, high contrast, grey Level and span Smooth auto-scaling and manual scaling of level and span Minimum span (in manual mode) 2.5 C (4.5 °F) Minimum span (in auto mode)
Fast Auto/Manual Range Toggle Fast Auto Rescale
5 °C (9 °F) IR-Fusion® information Full Infrared or Picture-in-Picture Picture-In-Picture (PIP) 100 % IR displayed in center 320 x 240 pixels Full screen (PIP off) 100 % IR displayed in center 640 x 480 LCD
Image and data storage Storage medium SD memory card (2 GB memory card will store at least 1200 fully radiometric (.is2) IR and linked visual images each or 3000 basic (.bmp) IR images File formats Non-radiometric (.bmp) or fully-radiometric (.is2) No analysis software required for non-radiometric (.bmp) files
Export file formats w/SmartView™ software JPEG, BMP, GIF, PNG, TIFF, WMF, EXIF, and EMF
General Specifications Operating Temperature -10° C to 50° C (14° F to 122° F) Storage Temperature -20° C to +50° C (-4° C to 122° F) Relative Humidity 10% to 90%, non-condensing Display 9.1 cm (3.6 in) diagonal landscape color VGA (640 x 480) LCD with backlight (selectable bright or auto) Controls and adjustments
  • User selectable temperature scale (°C/°F)
  • Language selection
  • Time/date set
Software SmartView™ full analysis and reporting software included Battery Internal rechargeable battery pack (included) Battery life 3 to 4 hours continuous use (assumes 50 % brightness of LCD) Battery charge time using ac adapter/charger or dc car charger 2 hours for full charge AC operation/charging AC adapter/charger (110 V ac to 220 V ac, 50 Hz to 60 Hz). Charges battery while imager is operating. Universal ac mains adapters included. Power saving Sleep mode activated after 5 minutes of inactivity, automatic power off after 30 minutes of inactivity Safety standards CE Directive: IEC/EN 61010-1 2nd Edition Pollution Degree 2 Electromagnetic compatibility
  • EMC directive: EN61326-1
  • C-Tick: IEC/EN 61326
  • US FCC: CFR 47, Part 15 Class A
Vibration 2 G, IEC 68-2-29 Shock 25 G, IEC 68-2-29 {2 m (6.5 ft) drop, 5 sides} Dimensions (HxWxL) 0.27 m x 0.13 m x 0.15 m (10.5 in x 5 in x 6 in) Weight 1.2 kg (2.65 lb) IP rating IP54 Warranty Two-years Calibration cycle Two-years (assumes normal operation and normal aging) Supported languages English, Italian, German, Spanish, French, Russian, Portuguese, Swedish, Turkish, Czech, Polish, Finnish, Simplified Chinese, Traditional Chinese, Korean, and Japanese
Old 12/19/11, 12:42 AM
Default Re: Like New FLUKE TiR THERMAL IMAGER
Several places selling them new for $4495
Mold Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 15 1/3/12 1:14 PM
Fluke Thermal Imaging Training Seminar - Phoenix AZ jkaylor Thermal Imaging, Infrared Cameras & Energy Audits 1 7/15/11 7:27 PM
Fluke TiR Thermal Imager - $3500 OBO tjuliussen Inspection Classifieds 3 11/1/10 4:38 PM
Fluke Ti20 Thermal Imager now available jbonelli1 Ancillary Inspection Services & Additional Topics 0 4/18/06 9:14 PM
