Old 7/28/11, 10:47 PM
Charley L. Bottger's Avatar
Default How many heat related problems
Can you ID in the IR image one is obvious one is not
many-heat-related-problems-2500-mockingbird-pc-7-27-11-032.jpg   many-heat-related-problems-2500-mockingbird-pc-7-27-11-093.jpg
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/28/11, 11:55 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: How many heat related problems
Should have left all the markers off the thermogram to see who really pays attention.
I see what you are hinting at and it would have been nice to test that out with ultrasound to hear what those breakers were doing on the inside.
I'll keep my observations to myself and let everyone else play along. Good find!
Old 7/29/11, 7:22 AM
Ya did not need ultrasound to hear what the one breaker sounded like could hear if from ten feet away and I am hard of hearing??????
NACHI Member
State License # 130
Old 7/29/11, 12:37 PM
Brandon Clark's Avatar
Brandon Clark Brandon Clark is offline
1) I'm assuming the whole main breaker is bad as all the wires coming from it are of significant heat concerns.
2) The other right breaker showing 180+ degrees is near about cooking.
3) The whole panel needs to go in the dumpster
Old 7/29/11, 12:51 PM
The hottest temp on the main breaker was only 120 that was only 16 degrees above ambient so you would consider that as significant temp I think you need to take another look
NACHI Member
State License # 130
Old 7/29/11, 2:34 PM
David A. Andersen's Avatar
Which is more critical, a 200° 200 amp circuit breaker or a 200° 15 amp single pole breaker?
BPI# 5015804
Old 7/29/11, 3:05 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
What were the loads recorded, Charley?
R or R the 187 breaker and re-scan. Heat signature (tails off) is very indicative of a bad or loose connection.
JJ
Old 7/29/11, 3:54 PM
Here was the amp draw on the main the 187 was to obvious needs R & R the main breaker was the other concern look how it is wired and what the temps are
many-heat-related-problems-2500-mockingbird-pc-7-27-11-037.jpg   many-heat-related-problems-2500-mockingbird-pc-7-27-11-039.jpg
NACHI Member
State License # 130
Hire IAQ Professional dplummer Ancillary Inspection Services & Additional Topics 0 11/15/07 9:01 AM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
CBC - Province called on to force home-sellers to disclose property's problems rwand1 Canadian Inspectors 3 4/5/06 8:40 PM
