Images of easy moisture intrusion issue at a mechanical room for a large commercial building.
Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com Last edited by krichardson; 2/4/08 at 9:28 PM.. |
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here's one from a bank inspection today. View of basement wall with water coming down from ice damming. Sent to client in iron palette and posting here in rainbow for fun.
Was this backed up with a moisture meter? What was the readings at the cold areas vs. the warmer areas lateral? I always take moisture readings from a cold area and a nearby warm area. Moisture readings in concrete and brick can be funny, that way., Too much thermal bridging. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Also pretty obvious from the pool of water on the ground and the water stains on the wall. Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
LOL Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| New forum for mold & moisture intrusion | Iaqforum Deuitch | Inspecting HVAC Systems | 0 | 1/3/07 10:47 PM |
