Old 8/3/11, 7:42 PM
oboyer oboyer is offline
Default Moisture meters
Looking for advice on moisture meters to purchase for home inspection thermal imaging and mold inspections.
Thanks, Dan Boyer
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/3/11, 7:50 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Re: Moisture meters
Protimeter surveymaster. Without a doubt. Durable and accurate. I have 7
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 8/3/11, 7:58 PM
Sean Fogarty's Avatar
A good moisture meter is by far the most vital tool an inspector needs. No other tool is as important as this one.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 8/3/11, 8:05 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
For those that havent met Russ yet he is an octopus and his 8th arm is holding a phone helping a fellow HI.
Old 8/3/11, 8:23 PM
When I am not peeing of course
Donate here:
Melbourne, Fl 32901
Old 8/7/11, 1:21 PM
Brandon Clark's Avatar
Brandon Clark Brandon Clark is offline
Yep, the protimeter is the only way to go. I have 4 different kinds including the Home Dept Ryobi pinless meter, the Lowes General meter, the protimeter ,and the Sears EXETECH M0210 meter.
I got so tired of having to verify the other meters with my protimeter that I've quit using them.
Another thing to strongly consider is the type of display. Many of the meters will give you a digital reading of numbers or bars but that sucks for photos. Try taking a picture of a digital number or screen in a cabinet space. The flash will often void the screen or make you get the image at an exact angle. The protimeter has yellow and red lights that can be photographed in all conditions.
Old 8/7/11, 2:51 PM
James H. Bushart's Avatar
Thanks, Dan Boyer
This one has worked for me for many years.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 8/7/11, 5:29 PM
The protimeter also comes with a calibration device which ROCKS. There is nothing like using it to ensure your meter is working within its parameters.
Donate here:
Melbourne, Fl 32901
Old 8/7/11, 9:45 PM
Thanks everyone for the comments. You guys have always offered help when requested.
Sincerely, Dan
Old 8/10/11, 12:48 AM
Chuck Evans's Avatar
I carry a Delmhorst BD2100 with a variety of probes including: extension probe (on a painter's pole), deep wall probes and a hammer probe.
It depends on what you will be doing as to which type will better serve you.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 8/10/11, 8:18 AM
John McKenna's Avatar
John McKenna John McKenna is offline
Survey Master dual function with deep probe attachments.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 8/10/11, 10:11 AM
Bob Elliott's Avatar
My pin meter just stopped working when needed and I do not trust my pinless so I will look into the survey master.
Old 8/14/11, 2:42 PM
I'm the same way about not trusting my pinless meter. There just seems to be so many things that can cause a false reading for pinless meters.
Wish there was a meter that was more accurate in terms of false readings.
Old 8/15/11, 10:18 AM
David A. Andersen's Avatar
The pinless meter is designed to scan and then be verified with the pin.
It's basically like infrared scanning. Sou must verify your initial readings. Painless
BPI# 5015804
Old 8/15/11, 1:17 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
You can also check out the Extech MO295 as it is both pinless and pinned. There are multiple attachments for it. If you have one of the FLIR cameras with bluetooth you can use the Extech MO297, which is the same thing except with the bluetooth ability.
JJ
Fighting Mold — The Homeowners' Guide from CMHC mkyriacou IAC2 Indoor Air Forum 1 9/17/09 2:32 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
