Old 2/26/08, 7:06 PM
David P. Valley's Avatar
Default Money out the window....Literally
They are wasting so much heat at this opened slider, that the IR image actually looks like flames are pouring out the window opening. This is only one of many windows that are always left opened by the occupants, because it gets too hot in the uncontrolled baseboard heated units on the upper floors (according to Owner).
"Click to Enlarge"
Old 2/26/08, 7:11 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Money out the window....Literally
This is common in the older steam heat rental units here in Chicago.
They usually place the senors in the coldest unit.
This is why so many landlords have switched to HVAC units as a precurser to selling.
Let the tenants pay for it.
Old 2/26/08, 7:20 PM
That's what I tried to tell this Owner, but he told me that competition will take all his tenants if he made such changes.
Old 2/26/08, 7:43 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Same here, they put the Mexicans in the bottom units.
Old 2/26/08, 8:12 PM
relliott's Avatar
It might even be cheaper to give the upper units a electric baseboard seperate from the rest
Old 2/26/08, 11:39 PM
Banned
"Click to Enlarge"
Attachment 18941
David:
Interesting to see how a metal screen intercepts/reduces radiant energy emission from the closed right operable window!! Looks quite a bit cooler than the center fixed pane!! This a life size, not microscopic, version of the "Low E" coatings on glass.
Then again........Always a chance that a curtain may be blocking heat movement to that window. It is a pretty distinct sharp edge deliniation though!!
Old 2/27/08, 12:33 AM
Marc D. Shunk's Avatar
Banned
That is what they call the "double hung thermostat" here in the northeast, where old central steam boilers prevail.
Old 2/27/08, 1:01 AM
Dale Duffy's Avatar
"Click to Enlarge"
Attachment 18941
Great picture David, unreal at best...!....
Old 2/27/08, 7:38 PM
William J. Decker's Avatar
Window glass, naturally, is a reflector of IR radiation. IR is, mostly, reflected by glass. There are special glasses (pyrex, which is a boron-silica product) that are better than regular glass.
Remember, Low E means low emissivity. The energy is absorbed and re-emitted.
Glass will transmit (allow to pass through) UV light, but it will refract the light into the lower IR frequency. That is how greenhouses work.
Low E glass depends upon the placement of the treated surface and is, usually, only effective in triple paned windows.
BTW: The Krypton-Argon gas between the windows has little effect on the transmittance / emissivity of the system. It is just an inert gas mixture that keeps out moisture if the seals are not broken. If the seal does break, the r value of the window is not significantly affected (only about .3 R per square foot).
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/27/08, 10:14 PM
Chimney heat loss:
Larry Kage, CMI
231 929 3525
Old 2/29/08, 2:27 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
And where do they put the senoritas?
Window well finishing rmuller Interior Inspections 7 5/10/07 9:11 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 4 4/23/07 8:31 AM
Window installation jmichalski Exterior Inspections 17 1/24/06 10:42 PM
