bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Well after lugging around several different cases for thermal scans and investigations, I decided I needed something mobile, heavy duty and big enough to hold my stuff.
I recently bought a Pelican 1560 case with the foam insert (got it for $129 on eBay) so I can build the guts of the case how ever I needed. I still need to add some of my other tools and a little more modifications to get it where I want. I plan on dropping everything about an inch to leave a recessed area for my laptop. Much easier to lug around and everything I need will be there with me. Plus it's sturdy as hell, so banging around in elevators and through other high traffic areas doesn't get me nervous, I was always worried some idiot would plow into me with my other case(s) and that would be all she wrote. ![]()
That's a really cool setup. Everything expensive or important I own goes in a Pelican case. You can sometimes buy these locally at camera stores.
nice setup. Good buy.
Brian,
My birthday is coming up soon... Very nice. John McKenna, CMI (TREC #4565)
Your link says: "This case comes with Pick ‘N Pluck™ foam inside." How does that work to make the spot to insert tools? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
That's nice Brian. I need to sit down and cull tools I lug in but don't use. One good thing about your setup is with a quick glance you know if you are leaving something behind... not that I've done that
Thank You. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
very nice
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Anywho...the pick 'n pluck stuff is pretty neat. The instructions recommend using an electric carving knife to custom fit items. I worked on getting my laptop in the thing this morning. Now I need to get some glue to secure the pieces of foam so they stay in one place. |
Pelican cases are pricey but worth every penny. I've got a couple I use for dive equipment. Only problem I've ever had with them is that the water tight gasket is so good that if the case has been subjected to low atmospheric pressure, like in an airplane hold, that the seal becomes so tight at sea level that you have to pry the lid open to equalize the pressure. Shouldn't be an issue for this application though.
| USA case law on Home Inspection | rwand1 | Canadian Inspectors | 10 | 5/24/09 12:30 AM |
| IR Case For Belt | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 22 | 4/1/08 8:16 AM |
| Second hand mold stuff.... | tdietrich1 | Ancillary Inspection Services & Additional Topics | 2 | 3/6/08 11:14 AM |
| Case law on Home Inspections | rwand1 | Canadian Inspectors | 10 | 4/5/06 11:08 PM |
