On today's inspection I came across this stud bay that appeared not to have any insulation.
When I went back outside, I noticed a pillar (not touching the wall) in the exact location as the stud bay. There appears to be a small square box at the top of the stud bay that lines up with the boxed in header of the balcony. Overall the insulation job throughout the house was the best I've seen this year. This wall faces north. I was thinking solar heat load on the wall could have been shadowed by the pillar. Not. There is no conductivity to make the wall cooler/faster. Just a coincidence that the pillar and the anomaly are so close to one another? Any ideas? Last edited by dandersen; 12/9/09 at 12:24 PM.. |
I just noticed something else.
I took a scan of a leaking bathroom ventilator and I have a cool stud bay that would be directly below the other scan. There's also a pillar against this wall. Last edited by dandersen; 12/9/09 at 12:24 PM.. |
Those pillars are hollow inside and trap cold air inside. Even though they are not touching the exterior wall, they will have some effect on the normal ambient warming of the exterior wall from normal indirect heat from the earth.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Brian, I believe you nailed it.
By golly, I think you've got it!
Good job! I just love this place! |
We need something to hold this roof up.
Yes, the pillars are hollow. They have air vents in them. Last edited by dandersen; 12/9/09 at 12:24 PM.. |
Good Call....You are right on with your comment. A greenie for you. Thank you, David A. for helping everyone (here) learn. A greenie for you. Why don't you turn on your reputation scale? |
| Volunteer home inspectors needed to help elderly/disabled. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 11/13/06 7:33 AM |
| Panel help needed | dmacy | Electrical Inspections | 10 | 5/25/06 10:41 AM |
| Guelph inspector needed | aspisak | Canadian Inspectors | 0 | 2/21/06 10:12 PM |
