Old 2/1/12, 9:51 AM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
Default New FLIR I7 I5 and I3
These are not actually new cameras, but have been resdesigned.
Notable differences are the higher resolution on the I7 and I5 as well as the 29 degree lens for a wider view. I will have some images over the coming days showing the previous image and new image on the I7 and I5.
FLIR I7
FLIR I5
FLIR I3
An interesting oddity on the new I7 is that it technically has a higher resolution than a 160x120 camera with it's 140x140. For building diagnostics I still would not recommend the I7 over the E30BX and defiantly not over the E40BX. If you are in the building diagnostics world, come up with the extra money for one of those two.
They are all the same price that they were previously. To my knowledge the I3 is still the cheapest priced camera on the market at $1195.00 list.
JJ
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/3/12, 12:27 AM
Odany Bravo Odany Bravo is offline
Default Re: New FLIR I7 I5 and I3
How do you think the new I7 compares to the Fluke TIS
Old 2/3/12, 1:11 AM
Odany,
Unfortunately for you, you live in Florida and should not really be considering either camera. Your location generally runs lower delta Ts than most of the country. Thermal sensitivity is already very important for building diagnostics and even more so for you.
JJ
Old 2/3/12, 8:34 AM
Reece D. Welch's Avatar
Reece D. Welch Reece D. Welch is offline
Originally Posted by jkaylor View Post
Odany,
JJ
So what camera do you recommend for doing diagnostics in Florida?
Reece D. WelchBSA,CMI,CGC,CCC,HI,MRSA
Certified Master Inspector®
State Licensed General Contractor
State Licensed Roofing Contractor
State Licensed Home Inspector
State Licensed Mold Assessor
Offices: 121 S. DeSoto Ave Phone: 863-494-1560
Arcadia, FL 34266 Fax: 863-494-6233
www.HISofSWFL.com
Old 2/3/12, 9:03 AM
Shane Goguen's Avatar
Shane Goguen Shane Goguen is offline
I JUST got the i3 2 days ago (older yellow model) is there a difference between the older i3 and the new one worth noting? Cuz i can still send it back me thinks...
Old 2/3/12, 9:46 AM
Shane,
FLIR is really good when stuff like that comes up. When upgrades happen within a reasonable time frame you can call where you bought it and get it swapped.
The odd thing in your case is how your distributor didn't know. We were all given advanced notice on this and were allowed to swap out our inventory.
JJ
Old 2/3/12, 11:18 PM
funny thing is that i bought it directly from Flir!
Old 2/4/12, 11:36 AM
Really? That doesn't make sense. Ya sure it wasn't some website being crafty with their URL? I have seen some deceiving URLs pop up as of late that make it look like a manufacturer directly.
Ya know the more I think about it, I guess it is possible. Either way, give them a call, they will swap it.
JJ
Old 2/4/12, 1:05 PM
Justin Ashley's Avatar
Justin Ashley Justin Ashley is offline
I have the E40BX and it has a lot of features that is needed in a thermal camera. Although I could still upgrade, this is min. I would go with when purchasing a Thermal Camera. Make sure you are aware of the features that comes with a camera before deciding on one.
Justin Ashley
Certified Inspector
PH: 614-256-6505
Email: Justin@Fullloop.net
www.fullloop.net
Old 2/4/12, 3:34 PM
Sorry Reece, I didn't notice your question above.
I would agree with Justin. The FLIR E40BX would be your minimum. After that I would go with the FLIR E60, if you can afford that much camera. Remember you will want to allow for training in your budget as well.
Jason Kaylor - JJ
480-528-4045
Old 2/4/12, 9:11 PM
With my budget I will not be able to get the E40BX now should I wait another year or get the E30BX .
What do you think is the one thing the set this 2 models a part the most.
Old 2/4/12, 11:35 PM
Brandon Clark's Avatar
Brandon Clark Brandon Clark is offline
You'll be happy with one of these little fellas until you use a 320x240 - .05 sensitivity camera just one time.
Old 2/5/12, 11:16 AM
E40BX is actually lower thermal sensitivity at .045mk.
That is exactly why I recommend it for the building diagnostics.
Odnay,
The differences are:
thermal sensitivity - (noted above)
WiFI - not a huge deal but nice to have.
Blue Tooth - not a huge deal but nice for reporting if you add on the moisture meter (in your case) and/or clamp meter.
Video out - pretty big deal for marketing
The digital camera in the E30/E30BX only allows for side by side comparison. It cannot do fusion and David Anderson will be happy to know it cannot do picture in picture. The E40/E40BX allows for both.
You could always lease to own your purchase and easily afford the E40BX. Or at that point you could jump up to the specification Brandon was talking about and go with an E60 and level I training. Then use your current capital for level II once you get some field experience.
JJ
FLIR E30 and FLIR E30BX jkaylor Thermal Imaging, Infrared Cameras & Energy Audits 3 2/6/12 4:58 PM
FLIR T300 / B300 with $1000 off or ITC Level I jkaylor Thermal Imaging, Infrared Cameras & Energy Audits 10 10/13/11 9:39 PM
FLIR E60 FLIR E60BX Promo jkaylor Thermal Imaging, Infrared Cameras & Energy Audits 12 9/8/11 3:57 PM
What the heck is with FLIR? wdecker Thermal Imaging, Infrared Cameras & Energy Audits 56 6/21/11 12:21 PM
Flir offers FREE infrared conferences dplummer Thermal Imaging, Infrared Cameras & Energy Audits 5 3/16/08 11:48 AM
