I inspected a new House and it had not rained for a couple weeks.
I told the client that detecting moisture penetration once everything has dried up, does not work very well with the IR camera. It rained very hard the night before. When I showed up, we found 6 different moisture penetration areas in walls, ceiling and floors. This was a new house and none of the moisture could be seen with the naked eye. I was so glad it rained. Oh.. my..
mjohnson6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Says a 1000 words! Thats a powerful tool and a great show of professionalism to your client.
Were you surprised when you saw the moisture penetration? I bet the client was relieved they chose your inspection firm. I don't have IR equipment yet, but it's in the books for this year. Great work~ |
Out of curiosity John.
When you document places like that, you really can't push it to a recommended contractor as they may not see the problem to correct. So do you also tell them how to repair and where it is coming from? Sure you can assume window, but what if it is from the window above that and the IR does not catch that fact.? |
Bet there was some "Peel and Stick" that didn't get peeled and stuck correctly at the top of those windows...
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Moisture problems can be conducive to fungi-mold, decay and wood destroying insects that are not always visible. Recommend a mold inspection by a licensed mold inspector and all materials that have been exposed to moisture be removed and replaced during repairs, by a qualified Professional. Applying caulk and painting over wet areas should not be considered proper repairs. Recommend evaluation and repairs, as needed, by a qualified Professional This leak was coming from improper flashing in the roof-wall intersection above the MB. John McKenna, CMI (TREC #4565)
The contractor can hire me if he wants or he can just tear it all apart. |
When pics are included in the report, detailed explanations become unnecessary...
A builder worth his salt will investigate and correct quick enough, and the ones who aren't, you can't convince with 1000 words... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
ok, fair enough.
Just wanted to know how commited to exact cause ,the verbage is. Wet yes , but as we all know ,water can travel left , right and even bypass floors to get the next one or travel from the roof to the basement with no signs of moisture in between. |
Any documentation or photos of these occurrences as you described? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Really would like a reply/proof. thanx I'm off to see the "Wizard/paying client" and will return. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Come on Bob.
I was hired to find a leak that several roofing companies could not find.
It originated where a flat roof over a breezeway joined a brick wall on the second story. When the gutters backed up, the water would build up on the flat roof and run down behind the bricks and show up on the bottom floor (not the second story unit). The leak occurred at various locations and at different times all over the apartment complex. Some days it would leak at one place and on other days it would leak in another place. The mystery was that it always showed up on the bottom floor and no one could figure out why it happened in some many places, but never in a predictable pattern. The back up in the gutter system was the trigger and that happened in changing degrees, depending on how the tree droppings went into the gutters. When people would go up on the flat roof (after the rain was over), they could never see the "water build up" issue because the water had already drained off. I'm not going to tell you how I fixed it. John McKenna, CMI (TREC #4565)
| Moldy House Costs Builder $3 Million | dplummer | Ancillary Inspection Services & Additional Topics | 5 | 9/25/11 5:51 PM |
| Foam Insulation ? | wrandolph | General Inspection Discussion | 13 | 11/18/07 8:30 PM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
