Old 3/4/08, 8:45 PM
Charley L. Bottger's Avatar
Default Not convinced
Had this bathroom today with a large amount of tile everywhere walls,floors. I alway use the IR camera around shower stalls just for the heck of it knowing the reflective value of tile is not going to be very accurate. Today I actually observed a cold spot on the floor just out side of the stall and moved around at different angles and the spot stayed the same. I even tried two different palettes with the same results. So I am thinking perhaps a leak perhaps a reflection. No guessing here luck on my side, Raised floor and when I entered the crawl space low and behold the shower stall pan was leaking.
Still not convinced If I was seeing a reflection or actually had water between the sub-flooring and the tile on the floor. All I can say for sure is the drain pan was leaking
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/4/08, 8:49 PM
Michael J. Ashburn's Avatar
Michael J. Ashburn Michael J. Ashburn is offline
Default Re: Not convinced
Nice find Charley.
Ashburn Inspections
724-516-1665
Old 3/4/08, 9:53 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Good catch.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 3/7/08, 8:47 AM
Barry Adair's Avatar
Charley,
Proof the inspector's 5 senses are his/her best tools...how'd it taste?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 3/7/08, 9:41 AM
asargisian asargisian is offline
Good Job on finding the problem Charley
Old 3/10/08, 9:01 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is online now
The Neo-Angle shower pans are noted for having leaks in the doors, the doors actually fill with water and leak. or when the door is opened after the shower it will leak. furthermore while taking a shower the threshold will leak, spilling water on the floor in the area your IR camera is detecting. My two cents is be carefully in your wording is the pan leaking or the caulking bad and water intrusion is noted or could the door be leaking. The pan and drain may be perfectly fine.
I love the cameras
Rick Kie
Old 3/10/08, 10:29 AM
I love the cameras
See Pic above no door, shower curtain is used. I am always very careful where I direct the shower head no water splash allowed
NACHI Member
State License # 130
Old 3/11/08, 7:56 AM
I should have looked at the picture before i spoke. I assumed it was a fiberglass pan.
Rick Kie
