Behind the sheetrock.
What effect if any would it have on an IR scan for moisture? "I create controversy whether they like it or not" |
What do you think?
...and I'll tell you if your on course. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I think it could mess things up and not give good readings of what is going on in the wall cavity.
Carl what are we referencing here in relation to good readings are you talking strictly temp or just a thermal pattern
Finding true readings of the moisture in the wall cavity.
True readings of moisture in a wall cavity is not possible with thermal imaging regardless of vapor barrier presence.
The only way to determine what's going on inside the wall cavity is to physically look inside of it. David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? |
David,
I understand that all to well. I just want to know if the poly would or could mess up the quality of the IR shots. "I create controversy whether they like it or not" |
What are your suspicions or what are you trying to determine? David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? |
Stucco house with moisture barrier on the exterior and poly on the interior.
Moisture intrusion from the outside via leaks. The moisture in the wall cavity just bouncing back and forth rotting everything out. And the poly making the IR not work at its best. "I create controversy whether they like it or not" |
Jason Kaylor is a non-member guest and is in no way affiliated with InterNACHI or its members.
Polyethylene will most definately change your thermal signature. The real issue with polyethylene is its emissivity value. Poly has an emissivity value of only .10. Which means it will only transfer 10% of the thermal energy it absorbs.
The good news is, for example. If the barrier was consistant, but had a hole or tear in it, you could find a thermal difference in that area. The other good news is, even though it is only transfering 10% of the thermal energy it absorbs (once again if it is consistant) it would still show variance on one side or another. Bad news is, if it is not perfectly flat against the drywall or whatever else it is installed against, you could get a false reading. Remember, using IR is all about variances and image interpretation. A solid, thermally sensitive camera really helps in situations like this as well. JJ Last edited by Jason Kaylor; 11/30/08 at 11:24 PM.. |
Carl I shoot images of wet walls all of the time and I understand the reference to poly don't know If I ever ran across a poly lined wall or not. My thinking would be if the poly is making contact with the dry wall it will make very little to no difference in the thermal transfer between the wet area and the exterior of the dry wall one is shooting but I would state that contact must be present. This kinda perks my intrest would be very easy to set up a demo mock wall and shoot varying degrees of images where one can control the ambient surrounding the mock up, might just do that time permitting
OK...If the interior poly barrier is in perfect contact with the sheetrock, the barrier will have no effect since it will be able to transfer its heat signaturte to the sheetrock.
If the barrier is loose with air pockets or bubbles, those voids will create an insulation effect and block the heat transfer from whatever is behind the barrier. This will likely appear as a typical moisture signature with mottled hot spots. David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? |
We have a new site about leaking houses and I think the IR is very much a needed tool and just curious about the poly and maybe even house wraps such as tyvek causing things to be missed or just just exposed fully.
Here is the new site http://www.your-leaking-house.com/ And the new message board http://www.your-leaking-house.com/si...use.com/forum/ Carl "I create controversy whether they like it or not" |
...even though poly may have low emmitence, this won't be a factor since the camera is not looking at the poly. Conduction is a far greater factor and the poly will be able to transfer its heat to the sheetrock if its touching it.
David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? Last edited by dsorge; 11/30/08 at 10:49 PM.. |
I think everyone that is doing IR should check and see if the houses have poly on them.
