Old 7/25/08, 10:19 PM
William Warner's Avatar
William Warner William Warner is offline
Default Quiz Time!
It's middle of summer here in sunny west central Ohio.
Can anyone tell me if there's insulation in the 2nd floor ceiling of this new construction???
quiz-time-th780015.jpg quiz-time-th780005a.jpg quiz-time-th780005.jpg quiz-time-th780008.jpg
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 7/25/08, 10:38 PM
Barry Adair's Avatar
Default Re: Quiz Time!
how'd they do that
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 7/25/08, 11:22 PM
John McKenna's Avatar
John McKenna John McKenna is offline
When the insulation guy in the attic yelled out for the guy below to turn on the
pump and "let er'blow".... they guy below thought he said "snow"... and drove
off in the truck thinking they got the day off.
I would drive off too, if someone yelled snow at me, in the middle of the summer...
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 7/25/08, 11:27 PM
Dale Duffy's Avatar
Attachment 22924 Attachment 22925 Attachment 22926 Attachment 22927
I do not know anything about IR cams but I would say no, because I can see the sheetrock joints so clearly, probably not finished yet.
Am I close?
Am I right?
Or am I wrong?
Circle- Yes No
Old 7/26/08, 4:18 AM
Originally Posted by dduffy
Circle- Yes No
ok
now what?
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 7/26/08, 11:39 AM
David A. Andersen's Avatar
Someone just left the radiant heat on!
BPI# 5015804
Old 7/26/08, 12:02 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is offline
Climb up through the scuttle, and look.
I'd say no, based on the minimal information I have...
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Old 7/26/08, 12:11 PM
Am I close?
Am I right?
Or am I wrong?
Circle- Yes No
Not bad Dale! I'll give you an "A" for effort since you guessed correctly, but not necessarily for the right reasons.
It's the framing you see (trusses, rafters, etc) which would generally correspond to the drywall seams of course. One should be able to "see" this regardless if there is insulation or not. It's the temperature differences and effects between the framing and the drywall that we look at. If it's an uninsultated exterior cavity in this weather, as the images show, the framing will appear cooler than the panels. If it were insulated, the framing would appear warmer than the panels.
I won't go into specific physics of why unless you really want me too... I didn't think so...
Thanks for playing along!!!
Old 7/26/08, 12:16 PM
You are correct.
In this instance, one generally doesn't need much more information other than the A/C was running. Just an understanding of thermal dynamics with a little experience kicked in.
This particular house, there was no access due to the design. I think the insulating contractors ran into this problem as well and either failed to tell the GC or together they hoped it wouldn't be discovered. It was blown cellulose in the lower portions of the house.
Old 7/26/08, 3:53 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
They probably figured it was either too hot or too cold up there to go up and check.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 7/27/08, 11:35 AM
kweiss's Avatar
kweiss kweiss is offline
Assuming you have cooled the interior - no there is not. Found a whole single story wing like that Friday
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Full Time ? fodette Canadian Inspectors 3 6/23/06 9:36 AM
