Jeff R. Johnson is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have the i5 and noticed that there is a red glow behind the buttons when the unit is off, even sitting overnight. Is this normal? If it is, what is constantly running and draining my battery?
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Call Flir.
Also, The cameras never shut off. If you have a low battery, be sure you charge it when you get back to the office or you will end up destroying the battery. $150 to replace the battery. there is an internal battery to save settings and it must be replaced at the factory. If you don't use a charged battery to maintain these settings, you will drain your battery before it's time. It is the manufacturer's opinion that this battery will be replaced when you send it in for recalibration. How many people here intend to recalibrate their camera? Enough said. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
JJ |
| Thermal Imaging Seminar-July 10- NYS Approved for Home Inspector CE | bmerrell | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 6/24/09 10:07 PM |
| Courier left Thermal Camera at Door! | jbettencourt | Thermal Imaging, Infrared Cameras & Energy Audits | 9 | 9/24/08 6:44 PM |
| I wouldn't recommend this IR camera to anyone... | bgromicko | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 6/3/08 10:29 PM |
| razir thermal FLIR infrared imaging camera for energy audit and home inspectors | Will H. Roberts | General Inspection Discussion | 4 | 4/15/07 11:13 PM |
