mroach is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a Flir Bcam sd and I can't figure out how to take the temperature information off of the picture.
Can this be done on the camera or only in the software? Thanks' Mark |
| Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America) |
rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think its like trying to get the FLIR off your images. No. No. No.
If you want it off save the image in a JPEG. Then do some cutting Best Ron |
I think I remember Scott Wood, an instructor from one of my classes, saying that stuff would disappear if you saved the image with bitmap file format (.bmp) but I haven't needed it to try it.
May e i did not do correct Best Ron |
When I transfer my images and go to the software to delete the spot marker the only thing that is left is the temperate meter at the right. That is what I need to get rid of.
Thanks' Mark |
Mark,
I read somewhere on the FLIR website that you may need to call them to figure it out. Easiest way is to just crop the image, rename and save. |
then expand 400% with image software Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Thanks Chuck, I owe you lunch.
Mark |
With a FLIR all you have to do is open the image with their software and do a save when you close. The screen info will disappear and the image quality will be improved in the saved file. There's no real need to change the file type.
You should be able do delete all screen info except the span range. David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? |
Welcome. Only took a few minutes to do. We do need to get together for lunch some time.
I'm surprised that we haven't run into each other yet. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
In the Flir Ouickreport software, "save the file " below the file name you can choose the file type. Choose bitmap. It will go away. The bitmap is slightly larger in file size (225 vs 95). You can always go back and change it back to a JPG (7.5k).
It is then no longer radiometric. (you can't change anything, it is just a photograph). "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thanks, David. I had forgotten it was in Quickreport where one can do it and have been very busy without time to look it up. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Jeff Barnes publicly responds to Jim Bushart, Dan Bowers and others regarding Kansas. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 100 | 10/7/08 1:21 PM |
| Grounding and Bonding Information | jtedesco1 | Electrical Inspections | 0 | 9/17/08 5:13 AM |
| Questar Gas Information | rcooke | Plumbing Inspections | 0 | 9/17/07 9:39 PM |
| Recall Notice - CPSC Notice | pabernathy | Electrical Inspections | 1 | 1/25/07 7:34 PM |
