Old 11/23/11, 11:29 AM
Mark CDavis Mark CDavis is offline
Please Note: Mark CDavis is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Roof leak or insulation missing?
Still learning how to properly interpret these.
Parameters:
Used: FLIR e60
Temp inside: ~72-74
Humidity inslide: 39%
Temp outside: low 50s
Dew point was in the mid 40s.
We have water leaking on the upper right edge of the 2nd window from the right, now likely falling into the wall between the right most and 2nd from right window.
Question is: what is the source? There are cracked trim boards above the window, failing caulking above the window, or we also had roofing work on the right side where snow had previously formed an ICE dam...they claimed to put 3' of membrane over there -- the color is where I'd expect the edge of the membrane to be...and it shows on the other side of the wall, 3' up as well...(last image -- other size of roof "V")
As you can tell, looks like the previous homeowner had taken out some of the drywall.
Any expedited help is much appreciated,
-mark
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/23/11, 11:48 AM
Default Re: Roof leak or insulation missing?
Oddly, on the other side of the window (where there was no ice dam), it shows the same thing --
Really need to get a Moisture meter...I actually own a Delmhorst J-Lite (used primarily for wood working), but it doesn't have a drywall adjustement...http://www.delmhorst.com/products_wood.html
Given that I see the problem here as well, it makes me think it is NOT a roof leak?
-mark
Old 11/23/11, 12:00 PM
Totally different location, same question:
Old 11/23/11, 12:04 PM
To follow-up on the first set of images, water is dripping a story below into another set of windows (following a major wind-driven rain storm, I might add)
Old 11/23/11, 12:07 PM
Bottom floor area below leaking windows shown in first picture. Question is: is the leak coming down from the top floor or is there another window leak here?
Old 11/23/11, 12:49 PM
Charley L. Bottger's Avatar
Did you use a moisture meter on the ceiling you will find your answer there
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/23/11, 1:00 PM
Peter C. Russell's Avatar
Any exterior digital pictures?
Russell Inspection Services
New Hampshire state license # 57
Level I Thermographer, ITC
Certified Building Science Thermographer, ITC
Certified Building Analyst, BPI
Certified Commercial Inspector, ITA
Certified Septic Evaluator, GSDI #148
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
Old 11/23/11, 1:48 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
If it is a cathedral ceiling it needs an air channel above the insulation. If no channel is found it may be from condensation and trapped moisture.
For instance, cathedral ceilings were constructed
with 2 x 8 rafters for many years which meant that
only R-19 batts could be installed. When codes
upgraded to R-30, even 2 x 10 rafters would not offer
enough space for standard 10" thick R-30 batts. Now
insulation manufacturers are offering 8
14" R-30 high density batts which offer higher thermal performance
inch-for-inch than standard fiber glass batts with the added benefit of allowing space for ventilation and eliminating the need to increase the rafter size or add roof baffles.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/23/11, 1:57 PM
probably isn't close enough -- the bank with the leak is in the upper-right
Old 11/23/11, 2:00 PM
Interesting info on the insulation Kwood. Insulation was blown in and I think there is at least some gap between the top of the insulation and the roof in most places, but it may not be enough.
Charley- my wood moister meter showed elevated readings of 7-8% (from typ 6%) in some areas of the drywall...Put a lot of pinholes -- need an non-invasive version. Not sure how to adjust for drywall vs. wood...Not sure if this is high enough to be something to worry about or just condensation...
Old 11/23/11, 2:42 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
You won't get much condensation with that indoor humidity. Your bottom windows look like typical air infiltration. The ceiling appears to be wet but not saturated. Deteriorated caulking and damaged/cracked trim along with some wind driven rain might be the problem. Does it get wetter with wind driven rains at that elevation of the home?
Old 11/23/11, 3:57 PM
Looks like a combination of air/water infiltration.
Confirmation with a moisture meter and then destructive investigation.
Do you have any close ups of the exterior window casings and flashing.
Old 11/23/11, 4:22 PM
David A. Andersen's Avatar
I will bow out and let the "expert" John McKenna answer that one for you.
I'm only a lowly Level III Thermographer and should not be doing Home Inspections any more...
It's all well and good to help out the other guy, but "Dude" you need some training to go with your camera...
We can't scratch the surface of what is going on here.
You don't have the equipment or the training, never mind being in parts unknown.
As it has ice dam issues, you could be north of me. That's about I can tell you at this point.
We can guess till the cows come home, but it won't do you any good. This is not point and shoot digital photography.
My best recommendation is to advise your client that there is a problem there and they need an expert to locate the problem or just get the saws-all out and go for it.
Seeing it is just sheetrock and the house is new(er), the latter will be the most cost effective. They have to rip it all out to make the repair anyway.
As there is a cold spot, that means there is an opening. If there is an opening, water can get in.
Water/Air it doesn't matter. It needs to be fixed or they will be talking down the wall in the near future.
Peter Russel does these all the time. Give him a call.
Rip it out now, or a lot more later...
BPI# 5015804
Old 11/23/11, 4:49 PM
KEVIN WOOD's Avatar
Lets see what would Mike Holmes do? New windows, new roof shingles, new drywall mold proof of course, spray foam the ceiling and dont forget all new gutters and flashing.
OK Peter Russel are you good to go. LOL
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/23/11, 8:24 PM
Peter W. Bennett Peter W. Bennett is offline
With the device I made, you can attach a painter's extension pole
asphalt shingles remain 'best bang for your buck' rcooke Canadian Inspectors 0 9/2/11 12:15 PM
Level of detail in the InterNACHI Roof Inspection Certification course/ advanced desi kshepard Roofing Inspections 5 2/13/11 2:42 PM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Leak in bay window with copper roof hmiles Exterior Inspections 19 11/22/08 8:37 AM
