I found this on my afternoon inspection today. As per my normal routine, I fired up the furnace at the end of the inspection. But, I noticed this scorch mark during my visual inspection of the furnace. The furnace fired up and was running for about 5 minutes before I snapped this image (back side of gas fired forced air furnace).
Funny thing is the the Agent broke out the sellers disclosure and it had a reciept from a HVAC technician that clearly indicated that the furnace was functional and safe to operate. How could the Tech have missed the big scorth mark in the back of the furnace is beyond me. Anyways, any ideas as to possible cause? Cracked heat exchanger, maybe? For you HVAC Gurus out there Thanks, Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com Last edited by krichardson; 7/25/08 at 6:58 PM.. |
Would a cracked heat exchanger cause that?
I edited my original post to include "Cracked heat exchanger, maybe?" while you were posting your answer. Let's see what anyone else come up with. Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
The bottom of the heat exchanger is just behind that scorch mark on the back.
It looks like and old furnace. I wonder how the HVAC "tech" "tested" the unit. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I was just thinking that sure looks like an old unit...I'd call for a evaluation by hvac specialist....jim
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
You know guys as one gets older other things do not appear as old either. Has anyone ever really observed an old furnace I will show you one from today.
Kevin you may not have a cracked exchanger just yet but the proballity is very high. The unit could also be staying on to long for various reasons and the high limit switch not working. You have a problem there should be no heat marks on the outer shell of the furnace cabinet. I think you can wear a feather in your cap on this one. HVAC techs do not walk on water they can miss things also I see their work all of the time. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Looks broke to me!
You should be able to look in the burner compartment and see this type heat exchanger. Was the elevation about the same as the burners? The heat exchanger could have been worked on in it's past life and is touching the back of the cabinet. I would put my $$$ on the cracked HE. Time to get out the bore scope! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I'm up for the challange!! Thanks for the replies. Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
Sorry if I implied that - no offense meant. This is quite clearly something that needs a tech (who knows what's going on). Ironic that they want the original guy back out there. |
Love the photos. Which FLIR cam were you using?
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 28 | 10/21/07 6:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Misuse of Title | rwand1 | Canadian Inspectors | 40 | 10/15/06 8:29 AM |
