I recently visited a friends house under construction, and was giving him ideas on how to make his house more energy efficient. I suggested putting his attic access in his fully enclosed, unheated front porch to reduce the stack effect. (the trusses are open to the porch in the attic)
Do you think I made a good suggestion? |
| Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America) |
It might have been easier to just seal off and insulate the attic opening.IMHO
I can see how it would reduce leakage, but how do you figure it will reduce the stack effect?
Am I fighting over straws? |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I don't think so.
Most of the attic access openings leak like a sieve. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
If the delta T is right, the answer would be yes.
Not sure if you want to attribute it to stack effect, but it certainly contributes greatly to summer heat gain & winter heat loss. Not to mention the effect of leaking unconditioned air into nearby returns.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 8/8/09 at 11:58 PM.. |
Good image Chuck.
Great image and very nice web site!
I like your 10 questions... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Pretty cool shot Chuck.
Thanks. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Depends are there any codes that may apply on a new house that might indicate an alternate location?
Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
The attic should be outside the conditioned space and therefore the pull down stairs should be as well. We isolate the stair with a 2X10 frame and insulate to R-38. When you pull the stairs down there is a piece of plywood with a handle facing you so you can lift the insulation out of the way when you come up the stairs.
| Air Movement and the Thermal Gradient | kshepard | Interior Inspections | 1 | 10/11/07 5:48 PM |
| Professional Inspector Opinions Needed... | tdemers | General Inspection Discussion | 9 | 6/5/07 9:13 PM |
| For those in favor of licensing | gbeaumont | Legislation, Licensing & Legal Issues for Inspectors | 70 | 5/21/07 3:09 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 126 | 4/27/07 11:05 AM |
