Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/13/14, 1:49 AM
Jeff L. Gollaher, CMI's Avatar
Jeff L. Gollaher, CMI Jeff L. Gollaher, CMI is offline
Default Thermal Imaging Profitability
I do have it as an extra charge but not much success with it need to work on a better way to sell client on it.
Serving the Greater Sacramento Area
Old 1/13/14, 6:37 AM
Linas Dapkus, CMI's Avatar
Linas Dapkus, CMI Linas Dapkus, CMI is offline
Default Re: Thermal Imaging Profitability
Have you considered selling your equipment on Ebay?
Linas Dapkus, CMI
Infraspection Institute Certified Infrared Thermographer Level III # 8510
Dapkus Home Inspections
Rated #1 Chicago home inspector since 2006.
Old 1/13/14, 7:31 AM
Jeff Belrose Jeff Belrose is offline
Default
I just add it on. There seems to be little to no market for this on its own. That is why I would never spend over $2K for a camera (that is high to me as well) and will not invest in training. The IR companies don't get that it is a tool ( on par with a screw driver). Albeit, a very high priced one.
Old 1/13/14, 7:49 AM
With proper training and equipment, you can command $150-$200/hr.
We grossed over $70k in 2013 and will do over $100k in 2014.
Linas Dapkus, CMI
Old 1/13/14, 9:32 AM
dsmith29's Avatar
dsmith29 dsmith29 is offline
Linas, what I'm getting at. So for you its a separate service you offer correct and not included with the inspection?
Old 1/13/14, 11:07 AM
David A. Andersen's Avatar
Could this be some of your problem?
“If you build it they will come” only works if you build it!
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 1/13/14, 11:13 AM
Doug, it doesn’t matter if it’s part of the inspection or you do it separately.
If you do it separately it’s because they didn’t hire you to do a home inspection.
If you’re doing a home inspection and they’re concerned about mold, what causes mold? What tools do you use to identify the mold?
Mold testing tells you that there is mold in the house. Where is it and what did it come from?
If they treat the mold after a mold test, did they get rid of the real "problem" (elevated moisture)?
If someone mentions the word mold, 99% of the time they purchase the service.
The price of your service is based upon “potential loss”. If your client doesn’t perceive the potential loss, they’re not going to invest in your service, are they? Same as getting a home inspection. Why do they need inspection on new construction? It’s been inspected numerous times already… Right?
BPI# 5015804
Old 1/13/14, 11:29 AM
dsmith29's Avatar
Thanks David pretty much sums up what I was thinking. I see some who charge for it and those who don't and didn't know if there was a market solely for offering thermal inspection. When I get to offering it figured I would use it as part of the inspection and set me apart from others in area. Was trying to get a feeling of what most do on here
Old 1/13/14, 11:43 AM
Greg W. Mathias's Avatar
Greg W. Mathias Greg W. Mathias is offline
I charge for the Imaging but my clients do not realize it. I charge a lot more for my services than other companies but include the scan. Almost no one asks why I am more. They just book it and we are off. Most guys are charging 375 and I charge 450. The 75 is for the scan. I have never had anyone ask for it to be taken off. I also do stand alone thermal Inspections. I charge by the home or building square footage. .30 on a home and .40 on a commercial.
Old 1/14/14, 6:07 PM
InterNACHI Applicant
I charge for it separately, typically $125-$250 as an optional service in addition to the home inspection. I have a lot of demand for the service - of course I have no problem clearly articulating how we apply it, what it can and can't do, when and under what conditions we can derive the greatest value out of it. I also know how to properly report observations. It will typically add at least an hour to my inspection and reporting time and represents significant financial and training investment on my part - one that deserves to be monetized.
I have never used infrared imaging to check to see if an appliance works or to detect mold though - if I did, I probably wouldn't charge for the service either...
Chuck Evans (TREC #7657)
Houston, TX
Old 1/15/14, 11:16 PM
Larry J. Michael Larry J. Michael is offline
I was considering it. Looked at the 4k to 8k range. But the guys around here use it for marketing really. They buy the cheapest camera they can find and then say "use us we have an IR camera", looks great, but I don't believe the cameras they are using is showing them more than an experienced eye can find.
Jason Michael, CMI
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
HomeSpectors.com
Providing home inspections in Greensboro, Raleigh, Winston Salem.
Old 1/16/14, 10:25 AM
I know what you're getting at concerning the appropriate camera, but many people think they can find the problems without any camera.
That is somewhat true, but I find that you have to realize what it is your looking at before you can be confident enough to make this prediction without the equipment to verify and document.
You can have the appropriate depth insulation installed (which passes building code inspections), but does it really work? Until you have a thermal perception of how it actually works, you're not going to be very effective in telling the insulation contractor that they didn't do it right without documentation!
The most of you that have not grasped this concept; thermal imaging equipment is not just to locate and identify thermal exceptions. It is just as important to quantify and document a finding or a suspicion of defect to justify asking for remediation.
You can't get people to fix something that are not convinced that it is broken!
"You have a water leak in the ceiling, but you can't see it yet!".
"Oh really, and you expect me to tear down the ceiling and find it?!"
For those of you that can't seem to sell this service, you need to expand your perception of the technology. You do this by continuing your education and experience.
BPI# 5015804
Old 1/16/14, 10:36 AM
Kevin Richardson's Avatar
Kevin Richardson Kevin Richardson is offline
When I first started using Thermography, I sold ITI services separately, but now I include a General ITI Scan with every Standard Residential Inspection. I still market the additional services, like ITI Moisture, ITI Energy, and ITI Electrical.
I find the General ITI Scan to be a value added service and my clients appreciate it. I just simply raised my fees.
Kevin A. Richardson
Capital Infrared
Certified Infraspection Institute Level III Infrared Thermographer®, #7493
NACBI - Board Certified Commercial Building Inspector & Thermographer, #25685647
InterNACHI - Certified Professional Inspector® (CPI), #04091175
InterNACHI - Certified Indoor Air Consultant, #IAC2-00-3862
Website: CapitalInfrared.com
Office: 1-800-520-4367
Mold Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 15 1/3/12 1:14 PM
Ohio I know we can do it cbottger Thermal Imaging, Infrared Cameras & Energy Audits 0 12/26/08 12:31 AM
