Rye Zers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi,
The FLIR E-series e60 has thermal sensitivity of 0.05 C while the FLIR i7 has thermal senstivity of 0.1 Celsius. Both have thermal accuracy of 2%. Is the thermal accuracy over the entire range of the image or portion of the image (pixel wise)? If only part. Say there is a difference of 0.1 C in the portion, for example. 23.1 Celsius and 23.2 Celsius between 2 pixels. And if the the 2% accuracy is in different pixels or portions. Then it's possible the 23.1 would become 25.1 C and the 23.2 C would become 21.2 C turning the 23.1 and 23.2 to bcome 25.1 and 21.2 C? Then thermal accuracy would smear any advantage of the thermal sensitivty. Unless it is uniform across all image portion? If so. What circuit parameter(s) exactly cause the thermal accuracy to change? Those enegy audit. Can you really see difference between 0.1 C and 0.05C thermal sensitivity cameras? |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Thermal sensitivity and thermal accuracy are different specifications. There is another factor that you need to be aware of which is spot size. An infrared imager (imaging radiometer) cannot accurately measure temperatures at the single sensor (pixel level)
Spot size defines the minimum size object that can be accurately measured with a given lens at a particular distance with a particular imager. Anything smaller than the spot size cannot be accurately measured, although it may be readily seen. The spot size will cover some number of sensors and is an important consideration when performing quantitative anaysis. Thermal sensitivity specifies the minimum change in signal due to variation in incident radiation that the sensor can detect (i.e., how small a temperature variation can the imager see). The sensor can detect temperature variations in things that are too small for it to measure. Each sensor in the array will have a different response curve to infrared radiation. Each cell in the array will vary in signal response from other cells around it for the same incident radiation. This is corrected through the camera firmware (set during the factory calibration process) and is periodically normalized through the NUC (non-uniformity correction) process, which corrects for drift. Most current imagers NUC automatically. Basically, your imager will periodically flip a uniform temperature screen up in front of the sensor and readjust for the signal level of each pixel in the array so that it renders the same temperature across the whole array. Think of it like the mirror in an SLR camera. Every time your imager freezes and makes the familiar clicking noise, which is the screen flipping up in front of the sensor, it is going through the NUC process. The NUC process is what eliminates the "smearing" that you refer to. This is also the reason that your uncooled imager should be given time to warm-up and reach equilibrium in the environment in which you are using it. You may also notice improved image clarity an accuracy immediately after the NUC event. This is but one of many reasons that thermography is not simply point and shoot. If you are doing energy audits you should be focused on the thermal patterns (qualitative analysis) Yes you can see significant differences between imagers with different spacial resolutions and thermal sensitivities. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 8/17/11 at 3:00 AM.. |
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
How did we manage to leap from a question involving an i7 imager to theoretic maximums for sensor arrays? If you're working with an i7 now, I don't think that you will be bumping up against the upper limits of the technology anytime too soon. Your question might be better posed to someone involved in the design and engineering of detectors and imagers rather than on a user forum. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
I think we told him to research before he selected a camera!!! :-0
?? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
1mp IR camera detectors (you can only buy the cores currently) are in the $80k range. Keep in mind that is just the core. Its video currently supports 720P. I would say at least another two years when 320x240 will become the norm with 640x480 coming down to the 320x240 prices within two years.
There are a lot of other integration's that will be coming out before we see the 1mp cameras coming down in to the $20k range (where 620x480 is now). The biggest of which will be on board video storage and imagers that function more like a video camera that can take images rather than a camera that has a video out. I also wouldn't be shocked to see on board Android integration (not just WiFi, the entire OS) or maybe some sort of proprietary tablet style camera. The manufacturer that will take a quantum leap ahead of the others is the one that solves the problem that 90% of IR is reporting. There are ways to shorten that up with technology....some sort of auto tuning would rock, laser distance meter instead of laser pointer to calculate FOV automatically (among other things), auto emissivity (don't ask how that would work) and further integration with other technologies for building science and PDM. Another cool one would be to integrate the IR line scanner technology in to modern imagers for 3d imaging of moving parts. If anyone were to do something like this it would be Fluke since their parent company owns a company that makes IR line scanners, plus they have a huge industrial customer base already. Although who knows, it isn't like FLIR doesn't have the ability in the technology either. JJ Last edited by jkaylor; 8/17/11 at 5:41 PM.. |
measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Your right Rye. The wavelength of IR is longer than visible. Therefore, there is a maximum resolution that can be obtained with IR that is much lower than the resolution capable with visible light.
The smaller the wavelength, the better the resolution. Using your telescope example (slightly modified) - we can't focus a microscope on individual molecules not because of the limits of magnifying lenses, but because we are bumping up against the resolution of light (limited by the wavelength). So we use a different technology with a much smaller wavelength of "light" in the form of a scanning electron microscope. I don't know what that effective upper limit of resolution would be for Infrared. But I'm sure someone could calculate it. FWIW, Mark Last edited by measter; 8/17/11 at 11:34 PM.. |
I'm thinking now whether to transfer payment for a FLIR i7 with only 120x120 resolution. I plan to use it to see if aircondionining room is well insulated. Is this effective? Also mold water damage. At night. I always walk in the garden outside my house. I want the i7 to double as spotter of dangerous rats and snakes in the bushes. But snakes are said to be cold blooded. What is the temperature of a snake body with respect to the surrounding? Is it same temperature? Hope someone here can try to use their thermal camera to aim at snakes in the zoo. Pls. check the temperature as it would finally make me decide whether to get an i7 or wait for the 640x480 when it gets to the price of an e60 in 2 years. Thanks. Quote:
You should wait for more advanced technology to come along. Imagers will be far more advanced 10 years from now. They will be so inexpensive that they will sell them as disposables. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
hehe, how very true Chuck.
Rye, I am only guessing as to pricing....there is obviously no way of knowing this. I wasn't really talking about the price of the E60, I should have clarified that. I think the 640x480 cams will be in the $10k to $15k range within two years. Which is ballpark pricing on the T300 to T400 currently. As a side note, 640x480 has more than held its pricing over the past two years vs what we have seen in the 320x240 and the sub 160x120 markets. Realistically speaking the 160x120 has actually held its pricing as well. The largest drop has been in cameras in the sub 160x120 range and the 320x240 range. This is mainly due to the Ti32 being almost 1/2 the price of other 320x240 imagers, when it released. The Fluke 160x120 cams are actually the same price they were two years ago, up until last month. FLIR has gone from the i/b 40 to the e40/e40bx which is $1k less or about 20%. If you wait for something coming out, there will be something on that horizon, etc, etc, etc. There is basically zero reason to wait for anything in technology for more than a month or two.....even then that would drive you crazy over time. JJ Last edited by jkaylor; 8/18/11 at 2:14 PM.. |
Buying a high resolution imager in 2 years will put you 2 years behind your competition in experience!! Put a 120x120 in the hands of an experienced thermographer and a 320x240 imager in the hands of a beginner and see who finds the snake first!!
I can't beleive all this over an I7!?
That's not even a "real" IR camera in this industry (IMHO). Just go buy the thing and learn. In 10 years you can throw it away and get something better (as many have). "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
774 Manor Road Staten Island, NY 10314 718-514-3393 |
Oh no.. I just made a telegraphic transfer payment to the manufacturer in Estonia and will get it in a few weeks. Is there any thermal imaging course in Asia? Did you guys all learn it direct from a physical teacher or online course? The i7 is useful enough to sample the 7-13 micro environment. Without this device, there is no way for you to know if a metal is below or above 100 Celsius at a distance.. ain't it. Also I think the i7 would be useful as a thermometer to measure forehead of people who may have fever. This is accurate enough that it could be used as replacement for a non-contact thermometer in hospital, right? |
| Mold Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 15 | 1/3/12 1:14 PM |
| How about it illinois | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 13 | 8/19/11 6:07 PM |
| Look out John M here I come | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 14 | 12/28/08 11:01 AM |
| Ohio I know we can do it | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 12/26/08 12:31 AM |
