What does this look like to you?
1 Bathroom window next to a mirror.
2008 InterNACHI Member and Innovator of the Year HOME INSPECTOR PRO HOME INSPECTION SOFTWARE NOW ONLY $499 ($15O OFF!!) Easy to use, customizable Home Inspector Software that runs on Windows, Mac & Linux InterNACHI members receive 3 months of FREE home inspector website hosting List yourself in our Home Inspector Directory Free Watch our NACHI.TV Software & Search Engine Optimization videos! Help@HomeInspectorPro.com |
dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
window with leaking insulated glass
Without seeing more
Condensation build up? Poor weather stripping(seals)? or Broken thermopane seals |
I will give this through today and give the west coast time to wake up! |
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
You shut the left window just before the picture was taken?
cwhite2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
What is below the "middle" window? The left does look like a reflection.
My guess is that both windows have a seal problem on the bottom sash and the left window is unlocked.
You asked the right question for the next clue!!
Go Carolyn! Last edited by dandersen; 12/9/09 at 1:24 PM.. |
So we have a cold exterior, with a warm air vent immediately below. Warm air is being directed up towards the window surfaces. The cold areas are areas that are protected from the warm air flow by the window sills and the sashes. The window on the right does not appear as affected on the upper pane because it is not immediately above the register. Although the fan shape flow that the register creates is clearly evident on the bottom pane of the right window and as well the left window. The bottom pane of the left window shows a slower moving heat flow in its center because if you look at a register vent, the part in the center is blocked from direct upward flow. The left side also contains a reflection of the thermographer I believe.
Close? Steve Radabaugh Preferred Property Inspections Columbus Ohio Home Inspection Ohio Home Tips Westerville, Ohio |
I will post later. I have a tornado squeaking by me as we speak! Another in Jackson, TN heading down the pipe! Must get ! |
Be careful. Sending a prayer to you and everyone there.
