Old 10/11/09, 7:12 PM
ldapkus ldapkus is offline
Default The Upstairs Rooms Were Cold
IR scan revealed insulation deficiencies.
upstairs-rooms-were-cold-garcia-ir-005.jpg   upstairs-rooms-were-cold-garcia-ir-003.jpg   upstairs-rooms-were-cold-garcia-ir-002.jpg
Find an InterNACHI certified New York Home Inspector (and anywhere else in North America)
Old 10/11/09, 7:28 PM
Default Re: The Upstairs Rooms Were Cold
I don't see why the upstairs rooms should be colder than the downstairs rooms. After all, they're closer to the Sun--they should be warmer, don't you think?
Old 10/11/09, 8:14 PM
Peter C. Russell's Avatar
Linus, why does the date say 01/01/00
Old 10/11/09, 8:20 PM
I have no idea. I'll have to check it out.
Old 10/11/09, 9:34 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Deal killer - you guys and your fancy cameras!
Old 10/11/09, 9:54 PM
David Sorge's Avatar
David Sorge David Sorge is offline
Which FLIR model took those shots?
David Sorge (USN Retired)
FL License HI142
Infrared Certified Thermographer
Inspect-It 1st of Northeast Florida
Serving Jacksonville and surrounding communities
904-484-4847
dsorge@inspectit1st.com
http://www.dsorgeinspects.com
http://www.linkedin.com/profile?view...US&trk=tab_pro
We see RED...InfraRED
When we see RED...
You see $GREEN$
Ask us how?
Old 10/11/09, 9:57 PM
I think it's a BCam, nice find!
Old 10/11/09, 10:41 PM
BCam
Old 10/12/09, 11:25 AM
David A. Andersen's Avatar
This room gets colder in the summer, the hotter it get's outside.
Can you tell why?
BPI# 5015804
Old 10/12/09, 11:42 AM
bdoles2's Avatar
How about a little more info on the room, etc...?
Old 10/12/09, 11:46 AM
bdoles2's Avatar
Is that a light switch, or thermostat to the left of the door?
Old 10/12/09, 11:51 AM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
Thermostat is right below the air infiltration.
I also see this a lot with attic hatches. Out here a lot of the homes have their thermostat right below the attic access. In Arizona those attics can get over 170 degrees in the summer.
JJ
Old 10/12/09, 12:22 PM
This one is the attic access.
Not only do they conduct, but radiate as well.
It actually is a point of infiltration.
You can see the hot air being pulled between the insulation and the sheetrock.
Why is it being "pulled" into the house?
This is a 2nd floor bonus room.
Shouldn't stack effect cause the air to flow the other way?
BPI# 5015804
PVC for cold water? mnahrgang Plumbing Inspections 17 6/27/09 8:42 PM
Cold Room Finishing Gord AskNACHI.org Inspection Questions Forum 1 3/24/09 12:29 PM
My rooms are cold! jbettencourt Inspecting HVAC Systems 4 3/6/09 12:00 PM
Hot water first then cold out of cold side of fixture jberthiaume Plumbing Inspections 19 3/12/08 2:32 AM
cold climates: insulating floors w/plumbing above cold crawlspaces kshepard Plumbing Inspections 6 9/26/06 12:09 AM
