I would be interested to know what everyone is using to verify moisture found on low-slope roofs using an IR scan. Moisture meter, nuclear, or capacitance meter? Preferences when used on BUR, ballast, or rubber roofs?
Allied Home Inspections Tom Schlotter
| Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America) |
state that verification must be made by invasive test methods meaning cores or cores and moisture meter probes. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
When performing an infrared inspection of low slope roofs, it is imperative to verify thermal data with destructive testing. While infrared imagers can detect temperature changes associated with missing and damaged insulation, they cannot ascertain the cause of the thermal image. Core sampling or invasive moisture meter readings are the only known methodologies for accurately determining moisture content. Coupling invasive verification with thermal imaging not only improves accuracy of the inspection but also is required by ASTM Standard C1153 and the Infraspection Institute Standard for Infrared Inspection of Insulated Roofs. Under both of these standards cross verifying infrared data with other non-destructive techniques such as nuclear and capacitance instruments may be used to compliment, but not replace, invasive testing. Hope this helps. Jim Seffrin, Director Infraspection Institute 425 Ellis Street Burlington, NJ 08016 609-239-4788 SuccessIRies.com IRINFO.ORG IRINFOConference.com |
JIM; I appreciate your input on 'low slope' roofs. I have a client who has a 1/12 pitch torch down rubber membrane. My scan showed a failed seam which resulted in a core sample to confirm the intrusion was a 2 ft diameter leak.
The roofer who inspected wanted $12,000 to rip and replace (r&r). The manufacture spec patch saved approximately $11,000. A moisture meter and core tool are part of my thermal package. |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| Structural Links Page | mcyr | Structural Inspections | 52 | 8/1/09 10:54 PM |
| Really good free manuals on comp shingles | kshepard | Exterior Inspections | 22 | 3/22/09 10:37 AM |
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
