This is the north side of a vinyl sided house last summer during the morning.
No heat or a/c running. One section of siding is cooler than the rest. Could not find anything visual. There is a wood fabricated chimney to the right. The interior of this area is a sheetrock living room wall. Reflection? But it shows up in four pictures from different angles, even from up on the roof! Any ideas? Last edited by dandersen; 12/9/09 at 12:24 PM.. |
Is it condensation under the siding, being on the north wall it does not get direct sunlight during the day so it never fully dries out.
Digital pictures would help too. |
David I assume your pics are taken in rainbow any particular reason for that. I have not played with the rainbow or the iron gray much guess I should start HUH
Interior of house is cooler than exterior. Possibly insulated siding that had a peice replaced at some point with regular non-insulated siding
Chuck Connolly is a non-member guest and is in no way affiliated with InterNACHI or its members.
To my untrained eye:
Is the fireplace gas? Could it be the gas line? What is the thing to the bottom left of it? Hose bib? |
I don't think there is enough information to make a definative answer.
Could be a manufacturer defect in that particular panel. Could be a thicker material than the rest of the siding. Might have been damaged and replaced with a different manufacturer material than the original siding. Might be installed tight rather than loose like the rest of the siding. Might have been replaced by home owner and glued in place rather than installed properly (sounds strange I know, but trust me I have seen home owners do this) It's too uniform (looks like an entire panel) to be a major concern. I would probably note it to myself, take photos, and move on. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
I would like to start by commending everyone for their input in this brainteaser. This is a perfect example of why we wanted to form this section in the NACHI bulletin board. I applaud all of you. There are going to be things that we just cannot explain because of the limitations that we are bound by. However, in future inspections one of you may encounter the solution to this question and will enlighten the majority with your wisdom.
A little bit of tension has erupted on this thread since its inception because of previous posts and I sincerely hope that we can work past this. Everyone has an opinion and a theory. Let's be tolerant of one another. This is new to all of us and to the rest of the world. There is no expert in this field yet. Those that taught us what we know have admitted that they have achieved where they are by trial and error. We all have a perspective and an opinion. If you post it, be prepared to support your theory. Anyone questioning your theory is not attacking you, rather trying to broaden our perspective. Quote:
By the way, I have found some better pallets in QuickView versus quick report for some applications. I will post this later in another thread. As for other than black and white scans, we use what we have to, to depict the point were trying to make. It should be noted that any other setting degrades resolution. But the more you play with your scan, the better you may be able to relate the issue to your client. Quote:
The sheathing behind the vinyl seemed rather consistent for normal construction. Good call! Quote:
I also had these thoughts. Good consideration. |
I have quick report where do I find quick view .
Thanks ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I really like the mid-gray and mid-green palettes to make the contrast easier for the client to see.
| Do you unzip vinyl siding? | apfaff | Exterior Inspections | 13 | 7/23/08 8:49 AM |
| ALCOA vinyl siding one side warping, why? | Lynn Kelly | General Inspection Discussion | 4 | 5/23/07 4:32 PM |
| Vinyl siding window trim | jclark1 | Exterior Inspections | 14 | 6/6/06 9:46 PM |
| Vinyl Siding Install | psmothers | Exterior Inspections | 3 | 4/21/06 2:44 PM |
