pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi infrared guys!!! i'm curious about this one
how can you tell if the water is comming in through the foundation if the basement is finished -walls : drywall over spray foam insulation, -Floors : finished + sub floor can this be picked up by an IR since the surface measured is not in contact with the wather, if not how can you tell?? |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Bad windows on first floor . Wind blown through the siding and then it runs down the Tivek and down inside the foundation wall . Even can get into Basement from the roof . Be very careful on telling where the moisture is coming from. There is one ongoing in my area where they have spent a lot of time and money trying to fix this dampness in the basement . Two year old 2 story home . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Many times when there is moisture intrusion in the basement it comes in through the connection between the footing and foundation walls. In this case the thermal pattern would only extend part way up the wall from the floor. If it's leaking from the top of the foundation wall down it's hard to say without doing an evasive inspection.
Picture's and more info. such as age and style of the home would help. |
thx peter, that's what i tought, most of the time (if visible) you would ''see'' it in the floor area thx! |
Your welcome, good luck
Water usually drains downward and can be seen at the baseboards.
Sometimes you can even see areas of wet concrete or brick foundations, directly. I always back up suspicious images with a water meter. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Basement water infiltration usually stands out like a sore thumb given the correct condition. Since getting a much higher resolution and higher sensitivity camera, those conditions have become very easy to obtain.
Here's a few images of the latest basement water intrusions I stumbled upon. The first 2 are from water dripping from a pipe above(basement ceiling in the corner). The second 2-3 are from moisture coming through the foundation due to negative slope and water resting against the outer foundation wall. Both areas showed no visual signs of moisture meaning if I hadn't used my IR camera I wouldn't have noticed. Any of you guys are always more than welcome to use any of the images I post on here should you ever have the need. Last edited by bclark3; 10/22/10 at 9:52 PM.. |
Peter Hopkins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Any guys interested in attending a free moisture webinar tonight with Mr. Scott Wood and Peter Hopkins. 5pm Pacific (8pm Eastern) https://www1.gotomeeting.com/register/525472576
Count me in. Thanks
I took the FLIR ITC Building Science course presented by Scott Wood about 4 years ago. This is an excellent opportunity to see a professional who really knows his IR. He may not be NACHI Infrared Certified
As did I, are you sitting in. |
This should be worthwhile. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
No Peter, I just arrived in Kansas City this afternoon for the ITC Level I course and will be brushing up with my study guide and pigging out on some good old BBQ.
Enjoy the webinar, Scott is an authority of building science IR. |
Scott Dana is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Total galvanic reaction? | jtribuzio | Plumbing Inspections | 19 | 4/3/10 2:18 AM |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| What might cause this many cracks? | bhamilton | Structural Inspections | 15 | 2/25/09 12:44 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
