Client, today, asked to find the source of water intrusion into a 3 unit condo (duplex up, duplex down with middle unit on one floor.
Split faced block, but the roof was sloped and there is usually little problems with split faced block with sloped roofs. But the front had a peaked front wall (brick veneer over block). I could tell, just from the efflorescence and drip pattern. 1) Front view of the building. Please note that the 3rd level (above grade) had a small (4' wide) balcony above the 2nd level. 2) Peaked front face with a small flat parapet near the chimney chase. Note the efflorescence / drip pattern. 3) Interior regular picture at the interface of the sloped parapet coping to the flat coping. 4) IR image of #3. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Secondarily. The front ceiling at the 2nd level displayed signs of water intrusion. Since the balcony for the 3rd level was above it, naturally the owners thought that the balcony roofing was the problem.
But it was not. The space between the 2nd floor ceiling and the balcony had "Building Envelope Confusion" and condensation problems where it interfaced with the floor / ceiling space above the 2nd floor. Check out the pictures. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Nice catch Will
Typical Chicago Polish contractor construction. Keeps us busy during the rainy periods.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Actually an Irish masonry contractor. Many masons are hesitent to do through wall flashing on a sloped parapet, believing that the stone will fall off. Evidently, they don't teach pinning in Irish masonry schools.
It also seems like they don't teach building science in Architecture school either. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Which one are you suggesting? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
The nearest liquor store.
Now Linus, play nice.
To clarify my earlier post, with regards to "Irish Masonry School", this is what I meant.
In this area, there appears to be 4 different "schools" of masonry thought, i.e., I see things done in one of four different ways. I even see some masonry buildings that have two or more of these schools displayed (changed masonry contractors during the build). Please note that the people who work according to these techniques are not, necessarily, members of these ethnic groups. Probably the result of who trained them and/or where they were trained (if they were actually, formally trained). 1) Italian - Good quality work, great for repairs on the older masonry buildings. Use fairly large aggigate sand for the mortar, but the motrar is not over sanded. Square of concave pointing. Great flashing detail. 2) Irish - Also good with regards to the mortar mix, but smaller aggrigate sand. Tend more towards pre-mixed mortar. Mostly good flashing and lintel / brick spaces left open. OK for flashing, but will not flash under parapet wall coping for sloped coping. 3) Polish - Good speed. Do not butter the ends of the brick before placing but have a "helper" follow behind them and point the head joints (check by placing screwdriver in the head joint and pressing. The joint usually collapses). Tend to grout the lintel / brick space and cover or cut the lintel flashing. Usually do not use end dams on lintel flashing. Don't flash under coping stones. Add more sand to pre-mixed mortars. 4) Similar to the polich school, except they caulk the lintel / brick area instead of mortaring it. They usually pull out the weep wicks before they caulk. Do not flash under copings, but always install weep wicks instead. At least that has been my experience in the Chicago area. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Will,
Could you get to the roof? Would like to see a photo. |
the masonry facade is improperly installed
with lack of weeps and drainage the problem is visibly evident... the cam only confirms... Without a Cam, would you report the exterior facade as deficient? Hmmmm??? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 11/11/11 at 11:44 PM.. |
I am amazed and appalled at the stereotypes professed within this thread as if they are somehow factual...
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 11/12/11 at 5:27 PM.. |
| Water Pressure Problem | dcossar | Plumbing Inspections | 19 | 11/21/09 8:47 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
