Old 3/17/10, 12:30 PM
kweiss's Avatar
kweiss kweiss is offline
Default What's happening here?
Yesterday's townhome warranty inspection. 55 degrees and cloudy outside and 73 degrees inside, furnace running.
See the two IR pics of the ceiling to the attic. Note the clearly defined slightly colder areas. There were several of these in the main living area. Not going to report anything about these, but I am curious as to what is causing them.
Initially, due to the small temperature difference, I though maybe these areas would be under the attic decking for the HVAC access. That there might be missing or improperly installed batt type insulation under the decking. When I got into the attic, I found that there is no decking in these areas. The access was poor but I could see that there was blown certainteed type fiberglass insulation above this room. The insulation install was typical and adequate. Being blown in type insulation, there was variance in the level through out. No clearly define rectangle with less insulation were visible from the attic.
So what is causing the colder rectangles. Not something I normally see and I am curious.
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/17/10, 2:32 PM
John E. Mullarkey John E. Mullarkey is offline
Default Re: What's happening here?
My guess would be that the isulation was somehow compressed. Is this an older house that had the insulation upgraded? new insulation shot over existing typical batts that might have been compressed?
Just a thought
Old 3/17/10, 2:36 PM
Wayne B. Wilson's Avatar
With that little of difference , I wonder if it is compression , Or is it a different type of insulation . Any pictures from the attic?
Was the main duct in that area?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 3/17/10, 3:55 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
yeah I agree, it is compressed or a different type of insulation. It could also have been compromised in some fashion, but because of the exact shape I doubt that is the case.
Jason Kaylor – JJ
AC Tool Supply
VP of Specialty Products
Level II SNT-TC-1A
Infraspection Institute #8031
877/207-1244
AC Tool Supply
Energy Auditor Talk
Old 3/17/10, 4:17 PM
ldapkus ldapkus is offline
Convection Colder air moving behind the vapor barrier. See it quite a bit.
Old 3/17/10, 4:33 PM
kweiss's Avatar
One year old construction. Blown in fiberglass insulation. Did not take any pictures of the attic because they would not show anything. Typical new installation for around here, variable surface levels between 10 - 12 inches as is typical for that type blown in.
Compression?
NO signs of compression or disturbance at all in the insulation. Certainly nothing in a recognizable shape as indicated in the IR pic. While the area was not easily accessible, I could see the area above the pictured anomaly reasonably well.
Vapor Barrier?
I do not typically see a vapor barrier under the blown in insulation around here. Notice these areas were not along an outside wall, they were in the middle areas of the room.
Possible something laying on the sheetrock in that channel between the ceiling joists? Could not get close enough to dig in it.
Kevin Weiss
Level I Infrared
972-463-0887
Old 3/17/10, 5:41 PM
OK
here is a thought i wonder if something was left and insulated over. Like bags from the insulation.
Wayne Wilson
865-256-1490
Old 3/17/10, 7:14 PM
Jeffrey Moore Jeffrey Moore is offline
What was the temp in attic? If the attic was warmer than outside air the ceiling Delta is not as great as a wall. This could account for the smaller temp diff between the areas.
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 3/17/10, 11:23 PM
measter measter is offline
Please Note: measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes. That what I would guess. Looks like an air gap due to it being pretty consistent across the rafter spaces.
Why is this happening in america "home of the free"? gluck Miscellaneous Discussion for Inspectors 14 3/18/10 11:21 AM
What's happening here? dvalley Thermal Imaging, Infrared Cameras & Energy Audits 56 3/5/08 8:09 PM
Find out about what's happening for new electrical rules in the NEC jtedesco1 Electrical Inspections 0 6/16/06 12:57 PM
