Old 9/7/08, 2:43 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Window leak
Here is a cool pic I found the other day at an inspection.
Old 9/7/08, 2:44 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Default Re: Window leak
yikes
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 9/7/08, 3:38 PM
Hey Mark,
Do you have the digital image that you can upload. Was this images taken from the exterior of the building during the afternoon? What type of material is on the wall?
Just curious.....what do you mean "window leak"?
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 9/8/08, 1:34 PM
mnicholet's Avatar
It was an anomaly that I found during a scan on a cedar board and batt install on the weather side of the home. Moisture content was low on spot checked locations in this area and the homeowner, which was my client, informed me it has been leaking in the past. I basically, told them to monitor this area in the rain season for any moisture penetration.
What is your take on this thermal image? Are you saying it is not an anomaly? Your input would be appreciated. Thanks.
Old 9/8/08, 1:45 PM
Bob Elliott's Avatar
I am curious why the window is colder .if this was taken from inside as it appears to be.
Old 9/8/08, 2:49 PM
mnicholet's Avatar
Sorry, it is an exterior picture.
Old 9/8/08, 4:58 PM
John McKenna's Avatar
John McKenna John McKenna is offline
If the Client said the window has been leaking, did you tell her that the window
should have further evaluations by a qualified Professional, so she does not
blame you for the damage that may develop later?
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 9/8/08, 5:16 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Just from looking at the pictures it looks like 2 empty voids below the window. Maybe some minor leakage to the bottom right.
What time of day did you snap these? Time of day is HUGE for exterior scanning.
Old 9/8/08, 8:34 PM
Mark,
Well, it is very difficult to glean any good data while conducting an exterior scan of the building during the day.
If the owner provided information that this window has leaked in the past, then I would have conducted an interior scan of the window and surrounding area.
There may very well be some damage to the B&B siding on the exterior, but that would be difficult to tell from your IR images. The warm areas on the lower right could be thermal loading or reflections.
Hard to say.....do you have the digital image?
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Old 9/14/08, 9:21 PM
Peter W. Bennett Peter W. Bennett is offline
Default Re: Window leak Pre and Post Hanna in NJ
The red arrrows in the first photo show where I inserted the moisture meter pre-tropical storm Hanna. Only 8-9 % moisture. Hanna was only a 1 1/2 day away. I told the buyer that I strongly recommend ITI when I return to pick up the radon canister.
The second photo shows thermal pattern associated with moisture entry, post Hanna.
The third photo of post Hanna tells it all, 90.5 % moisture.
window-leak-pre-hanna.jpg   window-leak-post-hanna_ir.jpg   window-leak-post-hanna_visible.jpg
Old 9/15/08, 11:46 AM
mnicholet's Avatar
Here is another picture of water damage from a window leak found on the internet.
Need help flashing top of replacement window on brick wall !!! Bill Featherstone Exterior Inspections 5 6/26/10 10:25 PM
Window well finishing rmuller Interior Inspections 7 5/10/07 8:11 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
Window installation jmichalski Exterior Inspections 17 1/24/06 9:42 PM
