Mark CDavis is a non-member guest and is in no way affiliated with InterNACHI or its members.
Same parameters as last post:
Temp inside: 72-74, humidity inside: 39%, temp outside: low 50s ![]() ![]() ![]()
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I take an uneducated stab at it. Cold air falling from a window leak would also chill the base board. It appears the baseboard is insulating against some of the infiltration.
Chad Norlen SEI Inspections InterNACHI Member Certified Professional Inspector HVAC Journeyman - State of Idaho EPA Certified Universal Technician |
rswartz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks to me like there is rim joist leakage at the baseboard. Several window jacks make up the vertical lines under the first window. A leaky receptacle is the culprit under the large window.
Most windows are improperly installed due to the lack of backer rod and sealant around the window on the exterior.
"I create controversy whether they like it or not" |
Plan is to remove the whitewood (ick) trim around all the window banks that have Southern exposure (1000' elevation too) and replace with Hardie with 3/8" gaps, backer rod, and Sonolastic 150. Reflash as well.
Still trying to figure out if this window is actually leaking or not...Will remove the wood trim soon. I keep doing that for other window banks and keep finding missing sections of drywall where there was a previous repair...scary. Moisture meter readings -- both EM and invasive -- are quite good all over...EM shows 3-5 on the drywall, 6-8 on the wood trim, and sometimes 10 around the nail heads Meters are Delmhorst and Wagner. -mark |
How do you flash under the sill and out over the cladding?
Kinda curious ... You see the cooler area at the studs in the wall and at the baseboard - rim - floor as always. Where exactly was the water leak.
If the moisture meeter is reading only 3-5 and 6-8 are you sure you have a water intrusion problem? Is 3/8 hardiplank trim a good solution? What is the profile of the siding. I cant tell from your picture but it looks like vinyl with cedar shakes on top. If so I would make sure that the window trim extends past the siding detail, in the case of vinyl and shakes I would use 5/4 stock and by the looks of the window wall I would go with a low maintenance material such as PVC. Flashing should be used not only on top of the window casing/header but on top of the window itself. Also, eliminate the caulking. Caulking is no substitute for flashing. If you caulk these windows they will only be destined to fail again. Finally, the trim detail needs to change on the center window. Both ends of the header casing look like a good entry point. I would increase the elevation of the trim so it's a solid piece all the way across the lower windows. The detail that I see in your picture is very difficult to flash and the corners where the lower trim meets the header is a good place for water to enter. Before I did all the above, and the fact of the low moisture readings would guide me in this direction first, I would remove the interior drywall under the window and check for air infiltration. A simple solution, if this area is dry inside the wall cavity, is to buy a large container of two part spray foam and not only air seal the cavities but insulate them as well. Once this is completed re-scan the windows to see if you were successful. My comments are based on very limited info. that you have provide but I have worked on many window walls myself. If you want to talk feel free to give me a call, I would be more than happy to talk. Russell Inspection Services New Hampshire state license # 57 Level I Thermographer, ITC Certified Building Science Thermographer, ITC Certified Building Analyst, BPI Certified Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com |
Good info, Peter...
Windows with trim around them need three pieces of flashing. imo
The head of the window out and bent over the edge of the vertical trim on the window. The same at the trim above the head of the window. Under the sill behind the trim under the window and out over the cladding! Caulk and backer rod on the sides and between the window and the trim under the sill. Kinda like these. http://www.badstucco.com/properflash/properflash.html Any water that is in can get out over the cladding. "I create controversy whether they like it or not" |
A lot of the ones around here have no flashing and no moisture barrier under the trim.
http://www.badstucco.com/repair2.html "I create controversy whether they like it or not" |
The flashing that is under the sill and out over the cladding needs end damns on it.
Never 45 the trim around openings, might end up looking like this.
Can someone tell (or show) me how to tell the difference between an air and moisture anomaly with Thermal Imaging without using a moisture meter?
It seems that we have as much trouble with the moisture meters as the thermal cameras. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I would think this a air filtration nothing more. I see a outlet, Most likely Insulation has been displaced by the sparky. Wire feed from underside?
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Need help flashing top of replacement window on brick wall !!! | Bill Featherstone | Exterior Inspections | 5 | 6/26/10 10:25 PM |
| Renovating Your Basement for Livability | mkyriacou | Canadian Inspectors | 0 | 10/22/09 11:45 AM |
| WH blanket | badair | Plumbing Inspections | 5 | 7/2/06 7:10 AM |
