| Green Building Inspections Contains discussions about green buildings and specific concerns when inspecting them. |
http://www1.eere.energy.gov/buildings/news_detail.html news_id=17913 Savings of 18.5% for Buildings that Meet 2010 Energy Standard: DOE November 30, 2011 ![]() NREL's Research Support Facility, which was among the top green buildings in 2011, showcases higher efficiency strategies.Credit: Dennis Schroeder, NREL DOE announced on November 21 that its analysis shows buildings meeting a 2010 energy efficiency standard will use 18.5% less energy than structures using the previous (2007) standard. The latest version of Standard 90.1, Energy Standard for Buildings, Except Low-Rise Residential Buildings, will save commercial building owners energy and money, according to DOE's analysis. It will also help them meet their sustainability goals and reduce carbon pollution. When DOE issues a final determination, states are expected to review the new code provisions and update their building code to meet or exceed the energy efficiency of the new standard within two years. Certification statements by the states are due October 18, 2013. The DOE noted that the newer version of the standard contains 19 positive impacts on energy efficiency, including some changes resulting from public comments. Among the modifications are new requirements for daylighting controls under skylights and commissioning of daylighting controls; increased use of heat recovery; cool roofs in hot climates; skylights and daylighting in some building types; reduced ventilation energy; supply air temperature reset for non-peak conditions; efficiency requirements for data centers; lower lighting power densities; control of exterior lighting; and occupancy sensors for many specific applications. DOE analyzed the energy codes published by the American National Standards Institute/American Society of Heating, Refrigerating and Air-Conditioning Engineers (ASHRAE) and the Illuminating Engineering Society of North America to determine the potential for energy efficiency improvements in buildings that adhere to the code. For its findings, DOE simulated 16 representative building types in 15 U.S. climate locations. The standard covers a wide spectrum of the energy-related components and systems in buildings ranging from simple storage units to complex hospitals and laboratories. Structures also ranged from those smaller than single-family homes to the largest buildings in the world. See the DOE Progress Alert, the final determination regarding Standard 90.1 THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
They may be saving energy, but not money. Utility rates are raising fast.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
Uh ... are you saying that people who reduce their energy usage are not paying less for their utility service than what they would be paying if they had not reduced their energy usage? You seem to be applying the "logic" associated with one who feels that it is a waste of time to wipe their butt since they are just going to be crapping again, anyway. It is precisely because of ever increasing utility rates that consumers should seek, immediately, the means to use the least amount of energy they can to operate their homes. Even if I reduce my energy use by 30% and my utility company doubles their rates --- my bills will be 30% less than they would have been otherwise. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 12/19/11 at 7:41 PM.. |
An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Companies of any type, utility or other, are only in business to make money and keep shareholders happy. They will not lose money. So, when you save energy, utility companies have to raise rates. Look at gasoline. Even when cars use less gas, the price just seems to go up.
I know. I have published that analogy some time ago ... but not as a reason to avoid energy efficiency. Do you actually believe that the power company plans to leave your rates the same if you choose to use energy at your current rate ... but will only increase your rate if you increase your efficiency? James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Due to the new EPA emission requirements scheduled to go into effect in 2014, over 32 coal fired electricity plants will close in Jaunary 2012. Another 30 could close before 2014. Sure their old, and emit carbon. But, the EPA is wanting better, cleaner air emissions by all companies, cars, airplanes, etc.
This is also what Obama wants. This is all for him, and the government, to control companies via these EPA tightened regulations. Close power plants, lower tax reveune to the governement and cities, lose jobs, raise rates dramatically, government control. Scary. CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
| Florida Licensing Bill - Action Soon | jburkeson1 | Legislation, Licensing & Legal Issues for Inspectors | 250 | 7/1/10 4:50 PM |
| Washington State Inspectors - Your Deadline Is Near | Mike O'Handley | Legislation, Licensing & Legal Issues for Inspectors | 54 | 4/14/10 9:15 PM |
| Thermal Imaging Seminar-July 10- NYS Approved for Home Inspector CE | bmerrell | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 6/24/09 10:07 PM |
| Gov't Energy Funds Coming Down The Pipeline | jmckenna1 | Miscellaneous Discussion for Inspectors | 2 | 4/7/09 10:13 AM |
