| Green Building Inspections Contains discussions about green buildings and specific concerns when inspecting them. |
Hello All:
This was lengthy article so I only took out a small portion. Paul Duffy, the vice president of engineering for Icynene, advises anyone considering the use of spray foam in an existing house to hire a home-performance specialist. “For a retrofit job, we recommend that you have a HERS rater involved, or a BPI-trained professional — someone who understands the house as a system,” said Duffy. “A spray foam contractor doehttp://epa.gov/dfe/spf_presentation_2009_epa_osha_niosh_cpsc.pdfsn’t necessarily have all of those understandings on the same level. … It goes beyond the skill set of insulators generally; it goes into the skill set of a building science professional.” Point about closed and open cell foam insulation is the smell can be so strong if not using the proper application or company. Good presentation info on SPF. http://epa.gov/dfe/spf_presentation_...niosh_cpsc.pdf THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 9/9/11 at 8:38 AM.. |
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Energy program goes retro | rcooke | Canadian Inspectors | 2 | 6/18/11 8:06 AM |
| Thermal Imaging Seminar-July 10- NYS Approved for Home Inspector CE | bmerrell | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 6/24/09 10:07 PM |
| Gov't Energy Funds Coming Down The Pipeline | jmckenna1 | Miscellaneous Discussion for Inspectors | 2 | 4/7/09 10:13 AM |
| Missouri Certifies Home Energy Auditors | jbushart | Miscellaneous Discussion for Inspectors | 7 | 11/19/08 11:44 PM |
