Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Green Building Inspections
Green Building Inspections Contains discussions about green buildings and specific concerns when inspecting them.
Old 9/12/10, 12:22 AM
Aubrey J. Kahn Aubrey J. Kahn is online now
Default Solar Electricity
Does anyone inspect solar electric systems and do you feel that they are worth the financial outlay at this time.
Old 9/12/10, 6:37 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: Solar Electricity
Please go to the control panel and add your location. The answer to this question could be different based on the state you inspect in.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 9/12/10, 9:57 AM
www.solarprofessional.com
http://www.homeenergy.org/
http://www.ases.org/index.php?option...d=14&Itemid=22
This is an interesting field if your in to that kind of thing. There are multiple configurations that can be put together. Same old thing on some of the defects boil down to workmanship, ie.. cables lying on the roof, the use of nonlisted componets, disconnects mounted off the vertical axis, missing labeling. If you are interested to go solarprofessional and sign up, you can download the past issuses as pdfs, tons of info
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 9/12/10, 12:42 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
As Greg stated it depends on what part of the country you are in. Here on Maui most of our grid electricity is generated using oil which is expensive and the costs fluctuate greatly depending on the oil market.
So here with our abundant sunshine the arrays can be smaller (more affordable) and the price is offset faster with typically a less than five year payback.
With a batch of electric and plugin hybrid cars and trucks coming out soon most people here with the photovoltaics plan to switch over saving even more money.
www.MauiHomeInspections.com
Old 9/13/10, 9:09 PM
I live in central Florida and my house faces true south. There is no obstructions to my roof and the south side is large enough to install 10Kw worth of panels plus solar hot water for a 100 gal tank. The quotes I have had for 5Kw plus hot water are in the $28 to $32 thousand. I am trying to figure out if it is worth the investment. I would be paying cash and right now am averaging about a 6.3% return on my investments. By my calculations it would take the best part of 15 years before the solar has paid for itself. Admittedly I am using a static number since I cannot predict what the future price of electricity will be although I know beyond a shadow of a doubt that the price of electricity will increase.
Old 9/13/10, 9:38 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
Aubrey,
I am not sure how far out this is, but it is more efficient and cheaper.
http://blog.cleantechies.com/2010/09...likon-corning/
I saw another interesting topic somewhere else, I will try to remember where I saw it. This family bought a house on a 30 year mortgage then installed solar for about the same price you are looking at. They had a similar payback period. What they purposed to do was to continue paying their current bill after the 15 year payback to reduce the mortgage down to about 20 years. Which saved a ton. This is providing they actually live in the house that long.
JJ
Old 9/13/10, 11:08 PM
Aubry,
did you factor in the FED, STATE and UTILITY rebates?
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 9/14/10, 5:33 AM
Greg Bell's Avatar
If you are ever in my area you might want to check out the Florida Solar Energy Center. I have taken some training classes there.
http://www.fsec.ucf.edu/en/
Greg Bell
Titusville, Fl
02111507
Old 9/14/10, 12:26 PM
the fed rebate is factored in. The utility company is KUA the most useless utility company in the state if not the entire universe (both known and unknown) has no rebates at all and if I happen to be at the end of the feed where the transformers are small I have to pay for them to upgrade the transformers so that there are no problems if I start feeding the grid. I will be upgrading the insulation in the attic to R30 or R40 and I am also looking into vinyl windows, double panes with Argon gas inbetween. The entire north side of my home is glass sliding doors and these will also be converted to low e.
Old 9/14/10, 12:36 PM
Greg Bell's Avatar
http://www.orlandosentinel.com/busin...0,222910.story
Greg Bell
Titusville, Fl
02111507
Old 9/14/10, 1:04 PM
Aubrey,
There is also a limited time program going on in FL for HVAC units.
www.rebates.com/floridahvac
It requires that a duct leakage test to the outdoors be done in order to receive the incentive.
JJ
Old 9/14/10, 2:19 PM
Banned
Solar definitely has a poor payback at today's costs per watt. For $$$ savings, it may be better to improve the efficiency of your use of electricity in the home by using occupancy sensors for lights, CFL's, better appliances, change of habits, etc.
I believe there are billions of barrels of oil still to be saved in our homes rather than make the switch to high cost/low payback options at this time.
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/14/10, 5:28 PM
Michael Larson's Avatar
Well said.
Maybe someday but not yet.
Michael Larson
Hudson, WI
Old 9/15/10, 1:55 AM
Brian E. Kelly's Avatar
Here Solar turns out to be a good investment as it is in much of the Western States.
http://estimator.solar-estimate.org/...al_estimator=1
Training Seminar for Solar photovoltiac and thermal pumping systems wdevries Inspection Education & Training 0 8/9/10 8:59 PM
Sharing Electricity dvalley Electrical Inspections 6 3/12/08 5:36 PM
Future of electricity prices in Ontario phinsperger Canadian Inspectors 14 12/18/07 7:09 AM
POLL- Paul Stay In The Electrical Forum pabernathy Miscellaneous Discussion for Inspectors 40 12/19/06 11:05 AM
Who Discovered Electricity - Article pabernathy Electrical Inspections 7 11/7/06 3:30 AM
