| Green Building Inspections Contains discussions about green buildings and specific concerns when inspecting them. |
| Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would like more info regarding the percentage cost diferential (labor inclusive) in the article with respect to the open/closed varietites and with respect to comparable r values for fiberglass as opposed to open cell.
Hey Nick,
Here's a few thoughts: 1. There is also soy-based closed cell with an R Value of R6/inch 2. Most spray foams are listed with initial R Values, and aged R Values. Ex: R6.8 initial, R6 aged, which is the long term R Value. Maybe this should be explained a bit to clarify for homeowner as some contractors promote initial R Values because they are higher. 3. Rodents will not eat it: You should check with a few manufacturers of soy based foam.You will find it can be a marketing ploy by contractors and is not true in most cases. 4. Most consumers are focused on the R Value of spray foams, however the airsealing capabilities of closed cell spray foam is mostly why it can be so much more effective that traditional insulation methods. 5. Spray foam is not a new product, it has been around for 20+ years. Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Master Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT eCertified Inspector IAC2 Radon/Mold Certified Infrared Certified |
thanks
Researcher and Technical Writer, InterNACHI |
This needs to be compared to other similar foam-based insulations, not fiberglass batt insulation.
| New article on soy-based insulation | inxil | InterNACHI & RealMatcher Blogs | 0 | 7/2/10 5:10 PM |
| Lighting Quality. Please proof this new inspection article. | gromicko | Green Building Inspections | 0 | 2/26/10 11:48 AM |
| Insulating Your House from CMHC | mkyriacou | Canadian Inspectors | 10 | 2/14/10 3:50 PM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 3:40 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 5:25 PM |
