| Green Building Inspections Contains discussions about green buildings and specific concerns when inspecting them. |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Many(such as the one shown) contain a mercury switch attached to a coiled spring that expands and contracts with changing temperature. If they get bumped out of level they will not control to the temperature setting. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
This is a reason for improper thermostat operation that I find a lot.
![]() Stats on unconditioned interior walls and leaking return air plenums pull outdoor air down/up the wall from unconditioned spaces of the attic or crawlspace.
| Thermostats. Please proof this new inspection article. | gromicko | Inspecting HVAC Systems | 4 | 2/27/10 9:54 PM |
| Lighting Quality. Please proof this new inspection article. | gromicko | Green Building Inspections | 0 | 2/26/10 12:48 PM |
| OSB vs. Plywood. Please proof this new inspection article. | gromicko | General Inspection Discussion | 13 | 9/24/09 5:26 PM |
| Roy the proof you asked for | wdevries | Canadian Inspectors | 55 | 7/8/08 11:30 AM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 4:40 PM |
