Go Back   InterNACHI Inspection Forum > General Inspection Topics > InterNACHI & RealMatcher Blogs
InterNACHI & RealMatcher Blogs Discuss the latest entries in the InterNACHI Blog and check out posts from the RealMatcher® Network.
Old 12/18/08, 5:20 PM
Chris Morrell, CTO's Avatar
Chris Morrell, CTO Chris Morrell, CTO is offline
Director of IT
Send a message via ICQ to inxil Send a message via AIM to inxil Send a message via MSN to inxil Send a message via Yahoo to inxil
Default Corrugated Stainless Steel Gas Lines: A Hidden Danger
Use this thread to discuss the entry Corrugated Stainless Steel Gas Lines: A Hidden Danger at the InterNACHI Blog
Old 12/18/08, 7:19 PM
Barry Adair's Avatar
Default Re: Corrugated Stainless Steel Gas Lines: A Hidden Danger
old news
http://www.wfaa.com/video/index.html?nvid=268648
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/18/08, 8:51 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Where was the city inspector????
Old 12/19/08, 12:38 AM
not on the job, obviously
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/19/08, 10:21 PM
Keith Runquist, CMI Keith Runquist, CMI is offline
Send a message via AIM to krunquist
Might be the part of the world I live in but I have never seen a gas line in the attic. One exception is when there has been an addition (that needs gas) that is on the other side of the house from the meter. Then I've seen black iron running along the bottom of the truss. Here's the stupid question. Why would you run CSST in the attic anyway? Doesn't it use less tubing if you run it in the floor joists/trusses? Same problem could occur of course.
Old 12/24/08, 12:15 PM
William J. Decker's Avatar
As usual, the problem is not the product (which is approved) or the roofers. The problem is the installer and the GC for not hiring qualified installers.
Just like Romex. The problem is not the product, but how it is used.
My theory, hereby labeled the "Decker Theorum" is that most construction defects occur "where trades collide". The siding guy and the roofer may both be good and qualified, but where their work joins (soffits, fascia, flashing) they do not work together to make sure that they bith understand the requirements of each others work. Seen it, many times, where an EIFS sided wall comes in contact with a new roof. Or when the framers do a perfectly good job, but the plumbers come along and notch the joists.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/17/09, 3:02 PM
John M. Volk John M. Volk is offline
Originally Posted by inxil View Post
Does anyone have a standard installation requirement for the product with drawings or photos? Should the bonding in the electrical service panel be identified so as to know the purpose of this ground?
A steel House rcooke Canadian Inspectors 4 3/20/08 12:42 PM
disimilar metals cbono Canadian Inspectors 6 1/15/08 8:41 AM
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 7:24 PM
Steel post question sspradling Structural Inspections 42 3/2/07 9:59 PM
Flexible stainless steel lines? five.five Plumbing Inspections 9 7/27/06 8:01 PM
