| InterNACHI & RealMatcher Blogs Discuss the latest entries in the InterNACHI Blog and check out posts from the RealMatcher® Network. |
Use this thread to discuss the entry Maintaining Your Water Heater at the InterNACHI Blog
Thanks Chris.
Chris informed me that the blog www.nachi.org/blog/ just had its 1,000+ view day.
Didn't know NACHI even had a blog.
I would note that you generally do not need to completely flush the tank of the water heater. More often I have found it may only take a gallon pail or or two to see clear water discharge. Most of the sediment settles and is sitting on the bottom or lower portion of the tank.
The other point being - perhaps a caveat when dealing with older tanks, where there may be an issue resealing the drain. Some have been known to not properly reseal. Just a few points to consider. Cheers, Claude in Canada Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
Mark, contribute! It is the best thing you can do for SEO. Read:
http://www.nachi.org/blog/2008/11/we...ternachi-blog/ Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
It's all I can do to keep up with my own blog... www.HeyMark.info
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| water heater recall | bwiley | Plumbing Inspections | 3 | 2/22/07 7:40 AM |
| Draining a mobile home hot water heater. | Steve Evets | Plumbing Inspections | 11 | 2/20/07 11:28 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
