Use this thread to discuss the entry New article: Installing Attic Insulation at the InterNACHI Blog
You guys missed the most important step. Prior to adding insulation in an attic should be the identification and sealing of air leakage points and bypasses. Without this step, your insulation becomes merely an “air filter” for conditioned air leaving the conditioned areas.
