| InterNACHI & RealMatcher Blogs Discuss the latest entries in the InterNACHI Blog and check out posts from the RealMatcher® Network. |
Use this thread to discuss the entry New article on lighting in clothes closets at the InterNACHI Blog
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Glad to see this in there Chris.......
Also, metal pull chains may be dangerous; if the base cracks, the chain can become electrified. |
White wire Goes to the silver screw and it goes to the outside of the bulb and this wire should be common to earth ( ground ) Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Even still ,does not that outside band become electrified when the light is on? Last but not least. How many guys test light sockets for reverse wiring? |
is a light socket an outlet? if so I do.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Hi Mark
Yes it is. So now you do,though it sounds like you don't. That's OK as I doubt anyone checks them or even most of them. Might even call them liars unless they actually get on a tall ladder and check the candelabra sockets hanging from vaulted ceilings.Yeah ,right. |
It is the same as the neutral bar in a panel not energised
| Clothes Closet Lighting. Please proof this new inspection article. | gromicko | Electrical Inspections | 12 | 2/26/10 3:33 PM |
| Lighting Quality. Please proof this new inspection article. | gromicko | Green Building Inspections | 0 | 2/26/10 11:48 AM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 3:40 PM |
| When were panels not allowed in clothes closets? | jtedesco1 | Electrical Inspections | 43 | 3/2/06 1:37 AM |
