droberts
(Donnie Roberts, TREC 10387)
October 2, 2012, 2:01am
I was trying to look up any codes on double tapping on buse bars. I looked on the TREC website and such and really found nothing about double tapping. Of course I know of the safety hazards of this. And I know there are panels that allow double tapping, what does anyone think about this? Is there any requirement far as code in Texas, other than just reporting it?
Thanks
Donnie
lkage
(Larry Kage, CMI)
October 2, 2012, 2:24am
2
droberts:
Thanks
Donnie
This help?
http://www.nachi.org/forum/attachments/f19/29063d1244149794-would-call-out-grounded-nuetral-conductor-terminals-small-.gif
droberts
October 2, 2012, 2:43am
3
There is also the neutral wire and ground wires double tapped in the same spot
lkage
(Larry Kage, CMI)
October 2, 2012, 2:48am
4
It’s a violation. Grounded (neutral) conductors should terminate within the panelboard to an individual terminal.
escanlan
(Emmanuel Scanlan, TREC# 7593)
October 5, 2012, 5:29am
5
droberts:
Thanks
Donnie
Prohibition of 2 grounded conductors, or any other conductor with a grounded conducter, under one terminal:
2005 - 2011 NEC, 408.41
Two or more EGC’s under one terminal limited by the panel manufacturer’s requirements.
Also the word is “buss” and not “buse”. In addition I expect you are referring to the double-tapping on terminal bars and not the buss bar.
