| Texas/TPREIA Inspectors This is a place for Texas InterNACHI members to discuss Texas inspection topics. |
Are damper blocks required for gas log lighters? I'm not talking about gas LOGS, but the ignitors (piece of pipe with a capped end and holes drilled in it).
All I can find refers to "gas logs" but says nothing about ordinary lighters. |
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is burning gas so it sounds like an easy recommendation for safety.
Got a PM regarding this. Texas Real Estate Commission has RFI on this that says they don't need to be reported deficient.
My worry is some idiot using one for heat without opening the damper. I'll work up some verbiage cma without claiming such as a TREC Deficiency |
It is required for the pilot, not for burner use...
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
You can never go wrong with mentioning a potential safety concern. A damper clamp costs 75 cents from the big orange box down the street. I hand them out like candy.
I personally would not sweat the log lighter scenario any more than I would worry about them using their gas range. I'm sure that it would not hurt to include a word of caution in the report if it makes you more comfortable. BTW: My son sooted up my whole living room and blistered the paint on my mantle when he lit my ceramic logset one Thanksgiving when I was away. I knew it had no clamp but considered myself smart enough to make sure the flue was always open before lighting. I failed to anticipate that my young adult son might unknowingly use it when I wasn't around. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
As far as just answering your question (and not my opinion)... the answer is NO, damper blocks are not required for a gas lighter/igniter.
Bruce Thompson Professional Inspector, Lic. #9199 Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area. www.TylerHomeInspector.com NACHI 06081394 |
| New article: Factory-Built Fireplaces | inxil | InterNACHI & RealMatcher Blogs | 0 | 8/2/10 8:30 PM |
| Factory-Built Fireplaces. Please proof this new inspection article. | gromicko | Ancillary Inspection Services & Additional Topics | 0 | 8/2/10 6:58 PM |
| Natural Gas Fireplaces | jcohen | Inspecting HVAC Systems | 3 | 12/18/08 2:55 PM |
