Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Texas Inspectors
Texas Inspectors This is a place for Texas InterNACHI members to discuss Texas inspection topics.
Old 3/14/10, 10:50 PM
Chris Mainka's Avatar
Chris Mainka Chris Mainka is offline
Default pools and spas
Is there any requirements for doing pool and spa inspections in Texas. I have completed the InterNachi course and have worked on and been around them all my life. I feel very good about doing the inspection but did not know if we had specific certification needs in Texas.
Thanks
Chris
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/14/10, 11:16 PM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
Default Re: pools and spas
None.
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 3/15/10, 5:38 PM
David A. Selman David A. Selman is offline
No "requirements" that I know of for doing pool and spa inspections. Just be sure you know the Texas SOP inside and out.
Good luck selling them. So far, most people don't want to spend the measly extra $35 for a pool inspection as part of their home inspection. Go figure....
Old 3/16/10, 10:30 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
$35.00 wow thats way to cheep I am just getting ramped up for them also thinking more like 60.00
Old 3/17/10, 4:24 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
$60 is cheap and $35 is ...well..are you doing a drive by? My pool guy charges $125 and I have yet to hear any buyer question it.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 3/17/10, 4:27 PM
Not sure the kind of folks you are talking to but 80% of my buyers get a pool inspection or they have already owned a pool and pass on it.
Old 3/17/10, 8:29 PM
Jeffrey R. Pope's Avatar
I don't give them the choice. Do you allow the client to let you skip the attic inspection or the crawlspace inspection? Will you reduce your fee if those areas are skipped?
Don't kid yourself - there's a ton of additional liability when the property has a pool or spa. If you do not inspect these systems (for whatever reason), you need to be sure the client understands the importance of a thorough safety check - and this should be WRITTEN in the report.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/18/10, 12:28 PM
I have talked with inspectors (one with more than 15,000 Inspections under his belt) that do not do not do pools specifically because of the liability. The extra $75 -$125 may not be worth it.
Old 3/19/10, 2:07 PM
kweiss's Avatar
kweiss kweiss is offline
I used to charge $75. Found a specialized pool inspector (older gentleman who built them for 35 years and is now semi retired) in the area who charges $110 - $125. I send all pool inspection straight to him. I do not up charge them or make anything. Experience has showed me he finds all kinds of things other inspectors miss. I am sure he has forgotten more about pools than I ever knew. I personally do not inspect them anymore, sending everything to the specialist.
I know this does not completely remove any chance of liability on my part, but I feel like it provides a better service to the client. I have no trouble getting people to do these when the house in question has a pool. I simply explain that pools are huge potential money sinks and that they need to be informed about them in the same way they are the home.
Kevin Weiss
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 6/12/10, 2:18 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
I read somewhere here in the forums about a pool inspector in San Diego that some HI's were referring to do their pool inspections. Can't seem to find the post now. Can anyone offer a recommendation?
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Old 6/12/10, 4:13 PM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you do not do pool inspections make sure you report on the child safety gates, alarms, latches and fences on EVERY one. Also make sure you inspect the sub panel as it is part of the electrical system even though you did not inspect the pool.
If you do inspect them, make sure client signs separate agreement for the pool. FREA requires that
Chuck
Old 6/12/10, 4:20 PM
Good points Chuck, thanks. My client does not have children, intends to have them sometime in the future, so in this scenario would you still report on child safety issues? I suppose one can never be too cautious.
My latest inspection did not have a sub-panel for the pool, it was wired into the main panel.
Do you have an example of a pool agreement that you could share? I'm with Allen Insurance and I don't see that they require a separate agreement. Again, good idea regardless.
Darin Redding, CPI
Facebook Like
619-663-8740
Old 6/12/10, 9:25 PM
Unmoderated Guest
Even with no kids, ALWAYS report on safety gates etc. The gates need to make it diffucult for the neighbor's kids who might want to take a swim when no one is home.
Allen doesn't require a separate pool and spa contract. CREIA has a good one and every little bit of legal protection helps.
Chuck
Old 6/13/10, 3:07 PM
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
Jeff,
While I certainly respect you and agree with you in theory, in Texas we have a standardized form for inspections. Pools are listed in the Optional System section and are not part of the bargained for report unless agreed upon prior to the inspection. I don't disagree that a safety check is warranted.
Now whether or not this would protect an inspector who was not contracted to inspect the pool, I do not know and don't want to be the first to find out.
FWIW, I did a pool last week for an additional $100. It takes me an extra 45 minutes to 1.5 hours (depending on the type of pool). A year ago, my client hired a local pool company to do a pool inspection at the home I was inspecting. The inspector charged my client $125. This same pool company charges an additional $350 if they have to dive the pool.
What do you do for $35 ?
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 6/15/10, 12:57 AM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
How to Inspect Pools and Spas. Free course.
Find a Home Inspector
How to Inspect Pools and Spas bgromicko Ancillary Inspection Services & Additional Topics 7 3/11/10 6:41 PM
InterNACHI releases new, FREE, online How to Inspect Pools and Spas course. gromicko Inspection Education & Training 1 3/8/10 6:22 PM
Inspection Checklist for Pools and Spas bgromicko Exterior Inspections 0 3/8/10 12:14 PM
How to Inspect Pools and Spas bgromicko Inspection Classifieds 0 3/8/10 11:52 AM
This House Met Code. jbushart Electrical Inspections 76 1/16/08 1:28 PM
