Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Texas/TPREIA Inspectors
Texas/TPREIA Inspectors This is a place for Texas InterNACHI members to discuss Texas inspection topics.
Old 12/26/09, 12:16 PM
John Cahill John Cahill is offline
Default Propane
What distance must a buried propane tank be from a residence in Texas?
Find an InterNACHI certified Delaware Home Inspector (and anywhere else in North America)
Old 12/26/09, 1:08 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is offline
Default Re: Propane
Not sure if Texas supercedes these requirements, but I found this:
http://www.inspectionnews.net/home_i...-clearance.jpg
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Old 12/26/09, 10:54 PM
Brian E. Kelly's Avatar
Default Re: Propane
Good question John. I would call the local Propan supplier and see ehat they have to say. Let us know what you come up with
Old 12/27/09, 12:58 AM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
Default Re: Propane
John,
It will be AHJ dependent. I could find no references by the State of Texas listing any specific distances. Individual AHJ's might have their requirements and reasoning. However, most will defer to NFPA 58 for ASME tanks. You can find a good graphic of NFPA 58 requirements, with distances above and below ground here http://www.propane101.com/propanetankdistancerules.htm.
Is this in relation to a specific issue?
FYI! It appears Texas has adopted the 2008 version of NFPA 58 http://www.npga.org/files/public/Sta...ns%20Table.pdf
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 12/27/09, 9:49 AM
Andrew W. Hinz Andrew W. Hinz is offline
Default Re: Propane
I suppose it would depend on the size of the tank to some extent. Anything over 500 gallons must be at least 10 ft. away from the structure. No expections or mention is made about above ground vs. under ground. Smaller tanks must be 10 ft. from any type of ignition sourse such as AC units, electrical boxes, etc.
Old 12/29/09, 4:04 PM
Default Re: Propane
Originally Posted by escanlan View Post
John,
Great link and Drawing Emmanuel, thanks.
Old 12/30/09, 11:58 AM
Default Re: Propane
The Texas Railroad commission regulates propane and they use the references provided.
I was inspecting a large home with a large propane tank and was unsure on requirements. I only see propane once a year. I always depart from the propane supply inspection and defer to the supplier who is regulated by TRRC.
Thanks all for the help and Happy New Year.
Propane drip leg mboyett Plumbing Inspections 1 1/11/09 9:23 AM
Subject: Safety Flash: Propane Tank Danger ksitzes Miscellaneous Discussion for Inspectors 1 6/2/08 12:04 PM
Propane gas to attic furnace brepanshek Inspecting HVAC Systems 5 2/21/07 5:06 PM
copper propane supply adooley Plumbing Inspections 2 2/21/07 12:55 PM
