Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 1/22/14, 8:16 AM
Roy Lewis's Avatar
Roy Lewis Roy Lewis is offline
Default Arc fault circuit interrupters Fla SOP
I noticed the Florida SOP electrical inspection items includes inspecting Arc fault circuit interrupters.
Do you call it out when they are not present even in older homes.
Thanks
Roy Lewis
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC132800
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/22/14, 8:53 AM
John Shishilla, CMI's Avatar
John Shishilla, CMI John Shishilla, CMI is offline
Default Re: Arc fault circuit interrupters Fla SOP
Yes, AFCIs should be installed to protect each bedroom
Arc Fault Circuit Interrupter (GFCI) breakers are designed to provide fire protection by shutting off current flow should sensors detect arcing in the protected circuit. AFCI protection of electrical outlets in bedrooms rooms is now required in new construction
Visit the InterNACHI Awards page
John Shishilla
State of Fl Home Inspector #21
Certified Residential Contractor CRC1330745
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
Pres of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
321-327-2950
Old 1/22/14, 9:03 AM
Roy Lewis's Avatar
I added that to my narrative library.
Thanks
Roy Lewis
Old 1/22/14, 9:48 AM
Bradley K. Toye Bradley K. Toye is offline
Thanks
Roy Lewis
2008 NEC expanded this to include most rooms in the house, not just the bedrooms.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 1/22/14, 10:25 AM
Joseph Burkeson, CMI's Avatar
Joseph Burkeson, CMI Joseph Burkeson, CMI is offline
I still see old blue-tab Square-D GFIC's which have been recalled and call them out too.
http://www.cpsc.gov/en/Recalls/1988/...ement-Program/
Yes, I'd personally choose a CMI every time over every other inspector. ~ Nick Gromicko, InterNACHI Founder
Certified Master Inspector - 2010
Florida Licensed Home Inspector - HI176
Florida Licensed Mold Assessor - MRSA208
Square-One Inspection "Assurance begins here"
Old 1/22/14, 10:44 AM
Roy Lewis's Avatar
I guess everywhere except where GFCI are required.
Where else ?
210.12 Arc-Fault Circuit-Interrupter Protection.
(A) Dwelling Units. All 120-volt, single phase, 15- and
20-ampere branch circuits supplying outlets installed in
dwelling unit family rooms, dining rooms, living rooms,
parlors, libraries, dens, bedrooms, sunrooms, recreation
rooms, closets, hallways, or similar rooms or areas shall
be protected by a listed arc-fault circuit interrupter,
combination-type, installed to provide protection of the
branch circuit.
Old 1/22/14, 11:00 AM
Paul W. Abernathy, CMI's Avatar
Paul W. Abernathy, CMI Paul W. Abernathy, CMI is offline
Send a message via Skype™ to pabernathy
If the code in effect at the time of construction did not require AFCI then don't call them out as a defect. However, it is perfectly fine to recommend them as a safety enhancement and to be considered. The SOP would be to test them when present.
Paul W. Abernathy
Manager, Electrical Codes & Standards
Encore Wire Corporation
Master The NEC Radio Show
“Promise me you'll always remember: You're braver than you believe, and stronger than you seem, and smarter than you think.” -RIP Dad, Love You!.10/10/2014
Disclaimer - All my posts on this forum are of my own personal opinion and in no way represent the opinions of Encore Wire, or other associations, organizations or affiliations.
Old 1/22/14, 11:52 AM
Roy Lewis's Avatar
Paul
That is what I've been doing .
Recommendations only .
The code snippet I posted was the 2011 .
That leads me to ask when did it go into effect ?
Thanks for your reply.
Roy Lewis
Old 1/22/14, 3:27 PM
Steve Taylor Steve Taylor is offline
1999 N.E.C. for original requirements for AFCI protection if I am not mistaken.
Steve Taylor
Taylor Inspection Services, Inc.
Atlantic Beach Florida 32233
904-206-0370
www.taylorinspectionservices.com
Old 1/22/14, 4:27 PM
Zack Salem's Avatar
Zack Salem Zack Salem is offline
Default recommended
I only recommend them because they are not code unless you are building a new home in my state
Old 1/22/14, 11:48 PM
Eric C. Van De Ven Eric C. Van De Ven is offline
It was in the 1999 code, and was adopted in 2001-2002 in Broward and Dade if I remember correctly. Palm Beach was earlier, 2000, I think.
I don't see anything wrong in recommending them, however, I would make sure that it is a recommendation with the notation, "may not be required by the local code when the home was constructed".
I don't make that recommendation because if I am going to make that one, shouldn't I make recommendations on upgrading other portions of the home as well? While we are at it, just knock down every home that is more than 20 years old.......sorry...that was the insurance company that hijacked my keyboard.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 10:51 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Can an AFCI offer GFCI protection gbeaumont Electrical Inspections 19 7/7/06 12:45 AM
Harmonized Ground Fault Circuit Interrupters jtedesco1 Electrical Inspections 5 3/21/06 9:48 AM
