Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 7/4/13, 11:48 AM
Todd A. Miller's Avatar
Todd A. Miller Todd A. Miller is offline
Default Clipped Gable wind mit
Need a little advice. Inspected a home with a clipped gable roof on all four sides. What hurricane strap photos does one take? The strap tieing down the gabel wall? That seems to be all I can Identify at this point?
Thanks in advance.
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/4/13, 12:47 PM
Glenn Fricke's Avatar
Glenn Fricke Glenn Fricke is offline
Default Re: Clipped Gable wind mit
Think about the clipped gable as a normal gable, you wouldn't qualify the end bolting or strapping of a normal gable wall for RTW so probably not here either. I'm assuming the anchorage points for the upper jack trusses are secured to the framing using right angle clips, so I would use that if present.
Old 7/4/13, 12:54 PM
Bradley K. Toye Bradley K. Toye is online now
Highly unlikely that all four sides are gabled from corner to corner, but if that is case, must photo the connection at the end of the truss over a wall. Not the intermediate straps holding down the bottom chord. Overall elevation photo would be helpful.
Old 7/4/13, 1:12 PM
Dominic DAgostino Dominic DAgostino is offline
Get an extension pole for your camera, drop a section of soffit, or belly-crawl out to the eaves on the side of the gable; you'll see the roof to wall attachment.
Dom.
Masonry Gable ends for Wind Mit tdennison Florida Inspectors 8 1/4/12 9:28 AM
Gable End Wall Bracing Can Be Complicated pcampbell Florida Inspectors 12 12/30/11 7:32 PM
Gable ends for wind mit inspections kmoore3 Structural Inspections 2 9/27/11 3:43 PM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
gable vents relating to wind mitigation dbonner General Inspection Discussion 2 8/4/09 9:22 AM
