Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 6/7/10, 10:42 AM
William P. Campbell William P. Campbell is offline
Default Flat roof section wind mit
I have a house with a flat roof of 180 sq ft. and the entire roof is 2500 sq ft. My interpretation is that it is more than 100sq ft of flat roof however is less than 10% of entire roof but should be marked flat roof because it's over 100 sq ft. Anyone who can help me figure this part of the form out would be greatly appreciated. Thanks in advance. Bill
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/7/10, 1:19 PM
Jay C. Murray's Avatar
Jay C. Murray Jay C. Murray is offline
Default Re: Flat roof section wind mit
Is the flat section over a porch or carport and attached to the wall or to the facia?
If so, it does not count.
If it counts, then calculate/estimate the roof square footage. The form says: 100 sq ft or 10 % of entire roof, WHICHEVER IS GREATER.
Under your example, the flat section can measure up to 250 square feet without being considered a flat roof. (10% of 2500 sq ft roof, is 250 sq. ft.)
Based upon the numbers you have provided, it is NOT a flat roof.
Your Home Inspection & Wind Mitigation Provider
Jay C. Murray
Florida Home & Insurance Inspector Chapter Board Member
Licensed General Contractor & Home Inspector
Serving Port St. Lucie, Ft. Pierce, Stuart, Palm City, Jensen Beach,
The Palm Beaches, & The Treasure Coast
Old 6/7/10, 1:37 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is online now
Jay, hello. the form says 100 or 10% whichever is greater. It only lets you check the flat roof option for 10% or 100 square feet. If the house mentioned was a hip roof except for the flat portion would you give the house a hip roof credit?
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Old 6/7/10, 1:49 PM
or
1   /ɔr; unstressed ər/ Show Spelled[awr; unstressed er] Show IPA
–conjunction 1. (used to connect words, phrases, or clauses representing alternatives): books or magazines; to be or not to be.
2. (used to connect alternative terms for the same thing): the Hawaiian, or Sandwich, Islands.
3. (used in correlation): either … or; or … or; whether … or.
4. (used to correct or rephrase what was previously said): His autobiography, or rather memoirs, will soon be ready for publication.
5. otherwise; or else: Be here on time, or we'll leave without you.
6. Logic. the connective used in disjunction.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 6/7/10, 2:06 PM
Bruce,
Please explain what you are saying by giving us the defination of OR.
Old 6/7/10, 2:28 PM
It is connected to the masonry wall it appears and is over a lanai slab with a screen enclosure. It is very confusing as it can be read simply as if it's over 100 sq ft it is a flat. It's too bad there is no one to officially interpret. Is there a source you have Jay that gives you great confidence that I can consider it a hip roof. Thanks.
Old 6/7/10, 2:34 PM
That is the problem no one including the OIR will give us definite answers on anything. I have contacted the oir and anyone else I could think of to get answers to questions I come up with in the field and there is no one to give us the answers. I try to answer as I interpret it in the field and even put notes on the form when things do not have a place on the form. I think you have a good plan, ask as many other inspectors as you can to see how they interpret it. Good luck.
Old 6/7/10, 2:41 PM
That depends.
We have 3 choices for Roof Geometry:
-HIP
-NON HIP (Flat roof do NOT count)
-FLAT
To be HIP the other roof shape can not exceed 10% of the total building PERIMETER.
The Square footage does not apply. Flat roof do NOT count as other roof shapes.
To be a FLAT roof, the total roof AREA is used to factor the determination. (Carports and patios attached to facia and walls are excluded.)
In answer to your question:
Lets agree that the roof in question is, 2500 sq ft (AREA) roof was of hip shape, with a 180 sq ft flat deck portion structurally attached to the roof.
First, is it HIP or NON HIP?
-Questimate the outer PERIMETER of the other roof shapes and the PERIMETER of the total roof. If any other roof shape, besides flat, is greater than 10% of the total roof PERIMETER. The roof looses its Hip status. In this case there is no other roof shape than hip and flat. Flat does not count.
Second, is it a flat roof?
-Figure the roof and flat decks total sq footage (AREA). Then calculate 10% of the total area of all roof shapes. If the Flat portion excedes 10% or in this case, 250 sq ft, it would be rated flat.
The FLAT roof cannot lower the rating to Non Hip. The FLAT deck does not exceed the greater of 100 sq ft or 10% of the total roof area (250).
Therefore, this is a HIP roof.
Hope this helps.
Jay C. Murray
Old 6/7/10, 2:46 PM
Smile Re: Flat roof section wind mit
Yes, the form itself:
"5. Roof Geometry: What is the roof shape(s)? (Poches and carports that are attached only to the facia and wall of the host structure and not structurally attached to the main roof system are not considered in the roof determination) "
I am completely confident.
Jay C. Murray
Old 6/7/10, 2:47 PM
Am I the ONLY one reading the form? LOL
Jay C. Murray
Old 6/7/10, 3:41 PM
Yea. I do appreciate your explanation. I will go with the hip. Thanks to you and Mike for your insight. Bill
Old 6/7/10, 5:06 PM
Anytime William. Keep asking questions, its the only way we all learn.
Not only that, as the inspectors working through the new form we are helping to develope a 'standard within the industry'.
Maybe it would be better to call it a 'standard interpetation within the industry'.
Good luck.
Bye the way, just cover you a s s and photo the junction were the wall and Flat meet. Point it out and include it in your photo attachment with something like:
Flat roof is NOT structural attached to host roof structure.
Or
Roof is Hip. Flat deck represents less than 10% of total Roof area.
CYA
Jay C. Murray
Old 6/7/10, 5:22 PM
Dennis J. Bonner's Avatar
Dennis J. Bonner Dennis J. Bonner is online now
The way I see it is, if its structurally connected and > 100 sq ft then its flat. if the flat roof is less than 100 sq ft, but greater than 10% of total roof, then its flat. Your pretty much screwed if you have a flat roof!
Old 6/7/10, 6:20 PM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
Can we see pictures?
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 6/7/10, 6:21 PM
Based on your data I would not mark flat.
John Shishilla
321-327-2950
Flat Roof Inspections jmaxwell Thermal Imaging, Infrared Cameras & Energy Audits 6 10/20/09 6:48 PM
Flat Roof Inspection Question - White Color rrunnels Thermal Imaging, Infrared Cameras & Energy Audits 23 2/27/09 7:51 PM
Flat roof question again! thalpin Thermal Imaging, Infrared Cameras & Energy Audits 3 6/19/08 10:36 PM
flat roof vent brepanshek Plumbing Inspections 2 10/13/06 7:36 PM
